Needed -- list of PPP hardware button combinations
(03-04-2022, 08:47 AM)tckosvic Wrote: Throughout these threads there are a myriad of hardware button, RE button combinations suggested to accomplish specific things.  At times these seem to be conflicting with other suggested combinations.  I am talking about; power on key, volume up-down, RE button, connect to charger,  or connect to computer.   Some instructions say, for example,  hold RE; plug in USB, OR hold power on: hold volume down, etc.
Would someone knowledgeable either point me (all of us) to a list of these key combinations or create a list?  Need the key combination and what is the purpose.  Also any special instructions such as: "Hold RE for 5 seconds after release of power on key".
Thanks,       tom kosvic
There are no such combinations. The PinePhone Pro boots from eMMC by default and to make it boot from microSD card (for example after your eMMC installation got corrupted) you need to hold the RE button at boot to disable the eMMC while booting.
This has to be done at boot of course, so not holding the button long enough or too late won't help. It would also not make any sense to hold the button while the phone is running, so steps such as "remove the battery" or "remove the USB-C cable" makes sure your phone is actually turned off. Simply follow the wiki instructions, as those are written to work and they are tested plenty of times, https://wiki.pine64.org/wiki/PinePhone_Pro#Boot_order.
RE: Needed -- list of PPP hardware button combinations - by fxc - 03-04-2022, 10:00 AM
  Anyone else having CPU hardware issues? 98cwitr 2 126 05-10-2024, 01:27 PM
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 840 02-17-2024, 04:04 AM
Last Post: fxc
  Pinephone Pro does not start with RE button pressed c0ssan 10 5,637 09-28-2023, 09:21 AM
Last Post: R0bbi3Mack
Question Where do i check/post/report bugs/issues with the software? (or hardware?) nande 4 2,685 04-02-2022, 10:31 AM
Last Post: wibble
  Needed -- Clarification of Boot SequenceInstructions tckosvic 3 2,257 03-04-2022, 06:20 PM
Last Post: fxc
  Sudo rm /var/lib/pacman/db.lck -- keeps being needed tckosvic 2 1,983 02-09-2022, 12:03 PM
Last Post: tckosvic
  Pinephone Pro hardware revision in the works? Gooberpatrol66 1 1,596 01-19-2022, 12:39 AM
Last Post: bcnaz
