Anyone else having CPU hardware issues?
If I put the slightest pressure or bump the phone, it completely freezes the OS and I've got to reboot. I've determine this acute pressure is right around the CPU area. I've adjusted the torque on the backplate screws, and more is better than less, but it still happens. Phone has NEVER been dropped.
Right now, the phone is basically used for a tethered wifi NIC for the downstairs desktop since moving it much renders it painfully inoperable.
Not really looking for a solution (unless you have one), but just wonder if anyone else has experienced this.
(05-10-2024, 06:51 AM)98cwitr Wrote: If I put the slightest pressure or bump the phone, it completely freezes the OS and I've got to reboot. I've determine this acute pressure is right around the CPU area. I've adjusted the torque on the backplate screws, and more is better than less, but it still happens. Phone has NEVER been dropped.
No issues here.
What OS are you running?
My Device: PinePhonePro (Daily driver)
My OS: DanctNIX Arch with Phosh
It sounds like a bad solder joint to me.
:wq
  Issues with Biktorgj Custom Modem Firmware JadenSki 4 5,308 12-19-2024, 04:50 PM
Last Post: JadenSki
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 4,827 02-17-2024, 04:04 AM
Last Post: fxc
  PPP HDMI issues Chief 2 4,643 05-25-2022, 10:23 PM
Last Post: Chief
Sad Sim card issues For_lack_of_a_better_name 0 2,259 04-11-2022, 02:53 PM
Last Post: For_lack_of_a_better_name
Question Where do i check/post/report bugs/issues with the software? (or hardware?) nande 4 6,936 04-02-2022, 10:31 AM
Last Post: wibble
Question Update issues For_lack_of_a_better_name 8 12,135 03-17-2022, 05:20 PM
Last Post: Fred Zyphal
  Needed -- list of PPP hardware button combinations tckosvic 8 13,727 03-05-2022, 04:56 AM
Last Post: fxc
  Pinephone Pro hardware revision in the works? Gooberpatrol66 1 3,617 01-19-2022, 12:39 AM
Last Post: bcnaz
