Issues with Biktorgj Custom Modem Firmware
So I recently decided to install Biktorgj's Custom Modem Firmware on my ppp, as it said in the documentation, there is no reason not to, and only added benefit. I installed it using this guide. After the installation, everything seemed to work fine (eg. sms, calls...). I then tried to communicate with the modem using sms as is described here. My messages didn't send, however, and I never received any responses. I also discovered a weird bug where my audio and mic will completely stop working for calls. I cannot hear or be heard by the other phone. Also when I check my voicemail, I hear no audio either. I don't know for sure if the firmware is causing the issue or not, but, it didn't happen until after the installation. Rebooting does not seem to do anything, however, it will randomly start working again before it quits once again. Any insight or advice on these issues will be greatly appreciated. I am currently running the latest stable version of Mobian with Posh. Thanks in advance!
(12-11-2024, 04:32 PM)JadenSki Wrote: So I recently decided to install Biktorgj's Custom Modem Firmware on my ppp, as it said in the documentation, there is no reason not to, and only added benefit. I installed it using this guide. After the installation, everything seemed to work fine (eg. sms, calls...). I then tried to communicate with the modem using sms as is described here. My messages didn't send, however, and I never received any responses. I also discovered a weird bug where my audio and mic will completely stop working for calls. I cannot hear or be heard by the other phone. Also when I check my voicemail, I hear no audio either. I don't know for sure if the firmware is causing the issue or not, but, it didn't happen until after the installation. Rebooting does not seem to do anything, however, it will randomly start working again before it quits once again. Any insight or advice on these issues will be greatly appreciated. I am currently running the latest stable version of Mobian with Posh. Thanks in advance!
this is what you need, it is a major problem that it is not mentioned in the pine wiki, FAQ, or on the Biktorgj git page; I found it digging through git bug reports even though it is Biktorgj's website. I have used it sucessfully to rescue my PPp and others in the forum have used it too, I have not yet seen any reports of this not fixing a PPp stuck modem. This also solves the stuck-firmware issues so you can freely flash modem firmwares after this fix without further issues.
"So, you're probably here because your modem suddenly stopped booting after a failed firmware ugrade or downgrade.
Long story short: something changed in the way Quectel builds their images and it seems like if you got a new board and attempt to flash an older image version the modem will stop being able to read its own EFS area and end up in offline mode with no IMEI."
https://themodemdistro.com/efs_recovery This is the site to get instructions, far better and easier to read than any other source including the git or this forum.
this seems to happen to  newer nanoSIM pinephone pros, not sure if it also affects classic allwinner pinephones; this issue pops up in this forum every few weeks.
it is sort of cool in that you end up rewriting the whole modem firmware including hand re-loading the IMEI printed on the modem's RF shield so it can fix nearly any modem problem without having to do any pin shorting and low-level reloading.
<edit>
I remembered that fastboot likes to run as real root shell so sudo su and then the command for example fixing the IMEI(or flashing) NOT sudo fastboot......
mobian@mobian:sudo su [sudo] password for mobian: root@mobian:fastboot oem fix_imei 12345678901234
(where 12345678901234 is the IMEI as shown in the RF shield on the back of the phone)
<edit>
Thank you for taking the time to reply! I will try this and will give an update afterwards. I assume that after following these steps, I reflash Biktorgj's firmware to the modem?
<edit>
I am not sure the version you end up with, but in the end after fixing the modem I flashed the current Biktorgj.  The fix website is also Biktorgj's.  There is also tweaks for phone audio. Biktorgj is pretty much the Megi of this modem module.
<edit>
After doing this and upgrading to a newer version of ADSP firmware, the issues were fixed. Thanks for the help!
  Help with modem and internet JadenSki 2 3,485 12-06-2024, 03:27 PM
Last Post: JadenSki
  Updating Biktorgj from 0.7.2 to 0.8.0 mikehenson 0 2,259 09-21-2024, 06:09 PM
Last Post: mikehenson
  Anyone else having CPU hardware issues? 98cwitr 2 3,568 05-10-2024, 01:27 PM
  recommendations on best firmware? hambonius 8 11,178 12-02-2023, 06:38 AM
Last Post: crocspot
  Modem diag output tjpresley 1 3,016 06-07-2023, 10:30 PM
  PPP HDMI issues Chief 2 4,594 05-25-2022, 10:23 PM
Last Post: Chief
  PPP modem firmware updater henrythemouse 6 10,465 05-10-2022, 10:28 AM
Last Post: henrythemouse
Sad Sim card issues For_lack_of_a_better_name 0 2,243 04-11-2022, 02:53 PM
Last Post: For_lack_of_a_better_name
Question Where do i check/post/report bugs/issues with the software? (or hardware?) nande 4 6,880 04-02-2022, 10:31 AM
Last Post: wibble
Question Update issues For_lack_of_a_better_name 8 12,022 03-17-2022, 05:20 PM
Last Post: Fred Zyphal
