Sudo rm /var/lib/pacman/db.lck -- keeps being needed
The command in the title above removes a file that keeps pacman from running updates.  Question is what is causing this to keep setting over and over and how to prevent it occurring.
I have used this several times but the lock keeps coming back.  Why???
tom kosvic
(02-09-2022, 11:30 AM)tckosvic Wrote: The command in the title above removes a file that keeps pacman from running updates.  Question is what is causing this to keep setting over and over and how to prevent it occurring.
tom kosvic
i do not have pp pro.
are automatic updates on?
i have pp regular and using manjaro. i noticed that quite often i need "screen" software for updates. if update process is run under graphical environment, probably phosh, and phosh restarts then update process will be terminated, thus leaving locks and broken updates.
"screen" is software which locks into system rather than normal process tree and "screen" provides window to the running terminal.
ssh is other option for updates.
tom kosvic
I think auto updates are done through discover. That is quite shakey.  It is always "fetching updates" and then says "up to date".  I use pacman for updates (manually) but it keeps shutting down due to lock file as per above..
  New PinePhone Pro. No sudo command or access to root password. DanNewman 4 5,758 03-01-2025, 06:38 PM
  Arch - what is the sudo password? LPIZ 1 4,306 03-15-2022, 10:13 AM
Last Post: tckosvic
  Needed -- list of PPP hardware button combinations tckosvic 8 13,433 03-05-2022, 04:56 AM
Last Post: fxc
  Needed -- Clarification of Boot SequenceInstructions tckosvic 3 5,767 03-04-2022, 06:20 PM
Last Post: fxc
