R U running from eMMC -- If so how?
On my PPP I was finally able to get the WIP4 tow-boot SPI installer to boot by holding down the reset switch and spamming volume down while booting, but when I tell it to install, it fails with:
Error: /dev/mtdblock0 not found
and
spi-nor spi0.0:
unrecognized JEDEC id bytes ff ff ff ff ff ff
spi-nor: probe of spi0.0 failed with -2
Has anyone else seen anything like this? For reference, this is from the first january batch of explorer editions. I would suspect a differing SPI flash chip perhaps due to chip shortages, but the "all ff's" tell me it's probably more likely related to the nasty reset thing I had to do to get it to boot in the first place. Has anyone else had similar issues trying to boot the spi installer, or using it?
Oddly enough, WIP3 installs.. odd... Maybe I can now install WIP4. Will update.
Confirmed. If you have the above errors with WIP4, try doing the following:
With WIP3 loaded SD card in the phone, reinstall battery and hold the reset and volume down buttons while powering up the phone. hold these until you see the Tow-Boot installer. Install WIP3. Then do the same thing with the WIP4 installer, without messing with the reset button.
Now to enjoy the full speed of my PPP, and with the SD card being a home or ext. data partition, as it should be!
R U running from eMMC -- If so how? - by tckosvic - 02-17-2022, 10:24 AM
RE: R U running from eMMC -- If so how? - by thechillhacker - 02-21-2022, 08:43 AM
Question The Case of the Vanishing EMMC DieSkaarj 8 2,812 04-20-2023, 03:27 AM
Last Post: DieSkaarj
  Mobian + tow boot + emmc flash = boot loop spropine 4 3,304 12-31-2022, 09:14 AM
Last Post: mburns
  How reflash my eMMC? IHaveALinuxPhone 2 1,495 12-01-2022, 05:39 PM
Last Post: IHaveALinuxPhone
  RK3399S running warm LPIZ 8 4,724 05-15-2022, 03:49 PM
Last Post: henrythemouse
  Not Bypassing the eMMC meansbs 3 2,406 04-02-2022, 06:25 AM
Last Post: fxc
  Re-flash the emmc For_lack_of_a_better_name 5 3,084 03-31-2022, 08:31 AM
Last Post: ragreenburg
  Please help! Can't install Mobian to eMMC Barugon 4 2,774 03-01-2022, 06:42 PM
Last Post: Barugon
  PPP Explorer Edition - Wipe eMMC The3DmaN 7 5,654 02-01-2022, 04:34 AM
Last Post: dukla2000
  Erasing the eMMC | Pinephone Pro Vermi 4 5,546 01-26-2022, 01:46 PM
