Very low battery (but charging) causes boot failures
(02-21-2022, 12:19 PM)wdt Wrote: I bet it doesn't run long
without having the back off and a DVM attached, you really are just guessing
If it is trickle charging ,,, the V may only go up .05V
(or you could insert an amp meter)
And most trickle charge maps have a time out, so unplug, replug every 1/2 hour
The USB C seems to partially bypass the charging map, so most of the time, this is the answer
Correct. It doesn't run long.  Are these charge maps somehow programmable?
RE: Very low battery (but charging) causes boot failures - by dieselnutjob - 02-21-2022, 12:26 PM
  upgrading u-boot--what version? where to get it? bsammon 5 127 8 hours ago
Last Post: dachalife
  uboot wont boot to SD card after upgrade jbradley419 7 1,026 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 335 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,437 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 796 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 655 11-22-2023, 11:47 AM
Last Post: fxc
Photo P{inebook Pro not charging Ome Ko 6 2,137 11-09-2023, 03:29 PM
Last Post: tomekdev
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,295 09-19-2023, 08:48 AM
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 2,023 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 838 07-13-2023, 01:50 PM
Last Post: PaulQ
