Very low battery (but charging) causes boot failures
Perhaps an overly aggressive battery protection map
I recently saw a video of a fully charged 18650, pierced by nail
Spit sparks, turned red hot (fully discharged bats will NOT do this, they don't contain so much energy)
The protections goes as so:
Under safe/undamaged level will refuse to charge (??..2.0V ..?)
Very low (?..2.7-2.8V..?) trickle charge,, C/100, for up to 30 min
When reaches safe level ((?..3.4-3.5V..?) goes to full charge rate
In this case, the charger rate is the limit, can only go to C/3 or C/4
Maybe the load on a flat battery drives the V down to trickle charge rate which will not run computer
Normal range for LiCoO is 3.6-4.2V
RE: Very low battery (but charging) causes boot failures - by wdt - 02-19-2022, 11:33 AM
  uboot wont boot to SD card after upgrade jbradley419 7 909 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 307 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,290 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 722 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 610 11-22-2023, 11:47 AM
Last Post: fxc
Photo P{inebook Pro not charging Ome Ko 6 2,066 11-09-2023, 03:29 PM
Last Post: tomekdev
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,228 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,934 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 817 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,984 06-14-2023, 07:20 AM
