Does GPS work on a separate chip or is GPS built into the LTE modem?
(11-08-2021, 03:08 AM)wibble Wrote: but still uses the Qualcomm binary firmware for the radio layer
Thanks.
Is it possible to replace the radio firmware?
(11-02-2021, 06:03 PM)tllim Wrote:
(11-02-2021, 09:58 AM)Mikoduso Wrote: Hi.
Pinephone.
in the LTE modem module.
Why was it decided to use the GNSS module as part of the LTE modem, and not separately?
Indeed, if the radio modem has a backdoor for remote connection and control, then the functionality of the GNSS module can be disrupted and the coordinates will not be correct.
RE: Does GPS work on a separate chip or is GPS built into the LTE modem? - by Mikoduso - 11-19-2021, 03:16 PM
  Supported Carrier and Modem Bands NachoMomma 4 1,573 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 535 02-17-2024, 04:15 PM
Last Post: vortex
Bug PinePhone modem keeps "disappearing" Kevin Kofler 14 5,654 03-22-2023, 05:28 PM
  modem not working michelinux 0 928 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 4,235 02-15-2023, 11:17 AM
Last Post: fxc
  firmware udate Quectel EG25-G modem alwi 7 5,376 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 2,863 07-06-2022, 12:35 PM
  The modem does not recognize Korean SIM cards (what?) bdicewk 9 4,133 06-13-2022, 04:12 AM
Last Post: zetabeta
  Modem Hardware bad? Not ready for 5g?? linux76 8 4,702 05-31-2022, 06:41 PM
Last Post: SwordfishII
  Modem in failed state, not sending/receiving SMS brb78 5 3,677 03-31-2022, 08:37 AM
Last Post: wibble
