How can I update Manjaro ARM w/ Phosh using Terminal?
short version:
$ sudo pacman -Syu
(sometimes ,$ sudo pacman -Syyu)
if using root, if activated:
# pacman -****
if user then:
$ sudo pacman -****
only updates package list:
$ sudo pacman -Sy
downloads only, without updating package lists:
$ sudo pacman -Suw
you might be interested about "wayvnc" and 'xtigervncviewer", which can be used for remote graphical usage.
you may to want disable automatic updates, seems to be easier in manjaro phosh.
https://wiki.manjaro.org/index.php/Pacman
RE: How can I update Manjaro ARM w/ Phosh using Terminal? - by zetabeta - 10-20-2021, 11:44 PM
  Using too much juice since last update Eugo 20 4,062 03-15-2024, 10:09 AM
Last Post: Eugo
  recent update Uturn 14 2,139 02-13-2024, 01:19 AM
  Manjaro: Settings doesnt open nbh 0 622 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,733 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,684 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 845 04-25-2023, 09:49 AM
Last Post: jakfish
  Latest update Eugo 21 8,754 03-09-2023, 05:27 AM
Last Post: Eugo
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 5,002 03-02-2023, 07:25 PM
  Backup and Home Screen Tinkering on Phosh jakfish 0 897 02-24-2023, 12:56 PM
Last Post: jakfish
  Can't install Manjaro thorensjubilee 1 1,073 02-09-2023, 08:17 AM
