Battery life: Maybe really a hardware issue?
#32
(09-19-2021, 08:01 PM)KNERD Wrote:
(09-19-2021, 07:43 PM)megous Wrote: Modem is cut off from power when the phone is off. KIll switch also cuts all power to the modem.
I guess you did not read the previous posts were I , and others posted losing battery power while the phone has been shut down.
I did. It doesn't change anything about how the pinephone modem powering works.
Your phone is probably broken in some way if it consumes power while off. It's not by design. All of my pinephones consume power in uA range while off (I measure it directly on battery terminals).
Or you have some very early batch (second one, I believe) that had some leakage issue, but that was quite small, and would take more than a few weeks to discharge the phone while off.
One of my pinephones started consuming 800mW while off, after I damaged it during development of the keyboard firmware a week or so ago, by shorting pogo pins. It now discharges overnight while off. So it's possible to damage the phone to exhibit similar behavior if you're unlucky. For example by laying the phone on a conductive surface without a backcover (even when it's off). You can basically short the battery that way, because one of the pogo pins is VBAT.
my website: https://xnux.eu
RE: Battery life: Maybe really a hardware issue? - by megous - 09-21-2021, 03:10 AM
  rough estimate of expected microSD installation life? andrewp907 7 3,688 06-10-2023, 07:55 PM
  volume down button issue sapphire 0 433 05-20-2023, 06:25 AM
Last Post: sapphire
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,525 05-10-2023, 03:31 AM
Last Post: fxc
  Megi's Kernel and Battery Life biketool 3 2,183 01-09-2023, 11:33 PM
Last Post: Canyonless
  UI crashes after unplugging USB device, seen on multiple OSes; is my hardware broken? slondr 1 990 11-05-2022, 11:31 AM
Last Post: slondr
Bug Pinephone Pro LTE issue DoesOkay 4 2,222 09-08-2022, 05:06 AM
Last Post: DoesOkay
  PinePhone Pro battery life Barugon 17 15,800 07-29-2022, 09:23 AM
Last Post: prog-amateur
  postmarketOS fixed battery issues Deadladyofclowntown 1 1,562 06-23-2022, 02:44 PM
Last Post: zer0sig
Sad How many other users recieved a phone with FAULTY HARDWARE? johnnykeys 16 13,226 06-22-2022, 01:05 PM
Last Post: zer0sig
  Unhappy with immature Hardware jojuma 1 1,525 04-18-2022, 01:18 PM
Last Post: zetabeta
