Total Noob. Need help booting from SD
(08-25-2021, 10:17 PM)wdt Wrote: Ignore the error 2. I think this about usb C video
What had you booted,, is it the Sd card? OR emmc?
i imagine that you are in a terminal, so
id
whoami
uname -a
mount |grep dev
lsblk
If you have sufficient permissions, edit (on emmc) /etc/shadow, make root passwordless
As I said before, search forum, all explained previously
(search .... passwordless OR shadow)
Just got off work, and I am about to take another crack at it. I just wanted to say thanks again for you're help. I'll let you know the results
As for what I booted, I BLEIEVE the SD Card, but I'll let you know
Okay. I found one thread and was reading, but then I kind of got confused. At first it says:
Quote:Then it depends. If you're on a computer that can run Balena Etcher, just select..
 But then a little further down it says:
Quote:We can't use Etcher on the Pinebook family, so we need to do it manually. It's not that hard as long as you're really careful
Sooo, can we or can we not use it?.
RE: Total Noob. Need help booting from SD - by Mattchublean - 08-25-2021, 11:32 PM
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 1,910 06-01-2023, 10:58 AM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,519 04-23-2023, 06:58 AM
Last Post: acruhl
Exclamation PineBook Pro shuts down immediately after booting zogkarndon 5 2,029 01-10-2023, 10:16 AM
Last Post: Perl6_user
Wink Booting Windows on bare-metal rk3399 SBC (no linux involved) strongtz 9 10,601 05-26-2022, 11:36 PM
Last Post: strongtz
  PInebook not booting with eMMC enabled aragaer 4 4,282 10-25-2021, 09:11 PM
  Manjaro i3 Edition not booting mtndew 0 1,595 08-23-2021, 06:21 PM
Last Post: mtndew
Video Problem Booting from SD card ezryder324r 0 1,481 05-19-2021, 02:42 PM
Last Post: ezryder324r
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,772 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  Booting to sdcard stopped working after emmc flash techiedog 3 3,957 12-31-2020, 06:30 PM
Last Post: Anarethos
  Booting - User device selection in U-Boot? Arwen 10 12,006 11-21-2020, 01:22 PM
Last Post: Arwen
