DOA Board? "UNSUPPORTED VIDEO"
(06-19-2016, 02:17 PM)xalius Wrote: Can you post some more specifics of your setup? Link the image you wrote to the card and with what tool you did. What power supply are you using, is your HDMI display HDCP capable and can do 1080P?
Sure - and thanks, Xalius
I will state right off the bat that I can't help you much with the question "the image you wrote to the card" because I have used MULTIPLE tools to try MULTIPLE images.
The power supply that I am using was ordered with the unit from Pine64...let me just say right now that if using the Pine64-supplied power supply is causing a problem with the Pine64 board here I'm probably done here Smile
Could I suggest an alternative approach?  I'll just start by saying I have no huge agenda/strategy for this card, so if someone would provide me with URLs NOT to the Wiki, but actual URLs to an IMAGE TOOL and an OS that you know work together, I will just do THAT...because at least then I can check OS/Tool off the list.  If I use a 'known good' combination of tool and OS, and it still shows nothing, I have data to go on.
Part of the early frustration was the number of seemingly 'official' and EXTREMELY similar looking sites for tools and builds.
EDIT: And yes, I have tried multiple displays including my Sharp Aquos that handles HDMI@1080....Not sure if this helps, but when the Pine is connected to one of the HDMI ports, the television seems to indicate that there IS something there, and it displays HDMI: 1080p ...but nothing ever shows
Thanks,
DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-19-2016, 01:26 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by xalius - 06-19-2016, 02:17 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-19-2016, 03:07 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by xalius - 06-19-2016, 04:13 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by Ghost - 06-19-2016, 04:13 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-19-2016, 04:39 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by phloog - 06-20-2016, 08:29 AM
RE: DOA Board? "UNSUPPORTED VIDEO" - by ptbrownie - 06-24-2016, 01:21 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by xalius - 06-24-2016, 02:09 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by ssvb - 06-24-2016, 02:38 PM
RE: DOA Board? "UNSUPPORTED VIDEO" - by ptbrownie - 06-24-2016, 02:39 PM
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 2,234 10-06-2022, 08:46 PM
Last Post: ihab
  Video conferencing aproject oxoocoffee 1 3,830 03-31-2020, 09:24 PM
Last Post: Dendrocalamus64
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 19,923 05-15-2019, 02:55 PM
Last Post: Thatoo
  My first Single Board! jjh221 4 8,461 04-09-2018, 06:52 PM
Last Post: jjh221
  sopine cluster board install Smurfbot 1 5,347 03-31-2018, 04:09 AM
Last Post: pfeerick
  What is the format that one should use for imaging SD cards on APINE64+2GB Board? Doryan 1 4,365 03-05-2018, 08:11 PM
  Which board to use? Dayve 0 2,812 02-18-2018, 06:31 AM
Last Post: Dayve
  Kodi on Rock64 board cenguix 2 10,046 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
  What are these pins on PIN board? dims 1 4,099 01-15-2018, 11:21 AM
Last Post: Luke
  red led + cat5 lights but noshow on DHCP list, no video mckenna.tim 1 4,613 01-24-2017, 12:03 PM
Last Post: Luke
