WhatsApp & Pinephone - What are the alternatives for collaborative comms?
If you must use WhatsApp, but don't need to be up to date every minute, you could also set up a VM with Android on your desktop machine and install WhatsApp inside. I did that for a while and it worked. It's far from practical, but enough to check new messages once a day or so. WhatsApp in Anbox would be much more convenient, but I'm not sure about the current status there.
I'm very much for opposing privacy invading technology whereever you can if you want something to change. Very often it's a matter of lacking knowledge about background and alternatives, these apps are just used for their convenience and wide spread use while people would be open for alternatives if they were set up for them. So if you can convince your client to use another platform, I would suggest something like the Matrix protocol. It's widely used by now, you can have a nice UI that will be familiar if you have used tools like Slack before and it's not tied to a specific app, you can interface with it however you like. If you read up on it, I'm sure you will find a lot of compelling arguments.
RE: WhatsApp & Pinephone - What are the alternatives for collaborative comms? - by kqlnut - 07-17-2021, 05:27 AM
  Pinephone boot. Richy_T 4 99 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 854 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 431 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 290 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,860 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,927 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 667 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,514 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 545 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,792 12-22-2023, 03:44 PM
