WhatsApp & Pinephone - What are the alternatives for collaborative comms?
(04-14-2023, 12:49 AM)Stephen21 Wrote:
(07-26-2021, 08:39 AM)Zombie Feynman Wrote: You can install WhatsApp inside Android Studio on a desktop or server. You need to be able to receive a text message with a verification code in order to create an account. That does not have to be the same device, so you can just use your PinePhone to receive the text message and type the code into the emulated WhatsApp on your desktop.
Aero WhatsApp
If you put the Android Studio AVD on a server, you can bridge it with Matrix and use e.g. Mirage on the PinePhone to access your WhatsApp chats. Alternatively, use WhatsApp Web or a VNC viewer to interact with WhatsApp directly and avoid the annoyingly complicated setup of the Matrix bridge.
If i use the Android Studio or other VM Android on the desktop, then create the WhatsApp account on the desktop. Then I can login in the WhatsApp web easily.
Now, my question is, if i remove the Android studio after logging in the WhatsApp Web, will i be logged out from the Web or will it still be active?
let it be clear, that i don't use whatsapp, or its web interface.
what i know, whatsapp web works little differently than signal desktop. whatsapp web is temporary and needs to be reactivated again for next time. if you uninstall whatsapp, then web connection is gone.
i think android studio usage is unpractical. i tried camera support and it's there, but cumbersome. so using it every time is not worth it and some guys .... not naming anyone here ... has some issues with google's android studio software and its android images with some components.
RE: WhatsApp & Pinephone - What are the alternatives for collaborative comms? - by zetabeta - 04-14-2023, 06:16 AM
  eSIM on PinePhone just_a_q 3 2,707 05-11-2024, 03:41 PM
Last Post: bam
  Pinephone boot. Richy_T 4 191 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 949 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 471 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 317 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 111,524 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,978 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 703 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,633 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 568 12-26-2023, 02:42 PM
Last Post: shengchieh
