PinePhone quickly crashes unless plugged to power
Aug 05 20:34:41 mobian ModemManager[488]: <info>  [sleep-monitor] system is about to suspend
Aug 05 20:34:41 mobian NetworkManager[405]: <info>  [1628188481.6787] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Releasing 'wds' client with flags 'release-cid'...
Aug 05 20:34:41 mobian NetworkManager[405]: <info>  [1628188481.6795] device (usb0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Unregistered 'wds' client with ID '19'
Aug 05 20:34:41 mobian eg25manager[408]: system is about to suspend
Aug 05 20:34:41 mobian eg25manager[408]: Sending command: AT+QGPSEND
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Unregistered 'wds' client with ID '18'
Aug 05 20:34:41 mobian systemd-networkd[284]: usb0: Link DOWN
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Releasing 'voice' client with flags 'release-cid'...
Aug 05 20:34:41 mobian eg25manager[408]: Response: [OK]
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Unregistered 'voice' client with ID '3'
Aug 05 20:34:41 mobian eg25manager[408]: Executed suspend sequence
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Releasing 'pdc' client with flags 'release-cid'...
Aug 05 20:34:41 mobian eg25manager[408]: suspend sequence is over, drop inhibitor
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Unregistered 'pdc' client with ID '1'
Aug 05 20:34:41 mobian eg25manager[408]: dropping systemd sleep delay inhibitor
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Releasing 'loc' client with flags 'release-cid'...
Aug 05 20:34:41 mobian eg25manager[408]: ModemManager object `/org/freedesktop/ModemManager1/Modem/1' removed
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Unregistered 'loc' client with ID '1'
Aug 05 20:34:41 mobian NetworkManager[405]: <info>  [1628188481.7185] device (wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Releasing 'uim' client with flags 'release-cid'...
Aug 05 20:34:41 mobian systemd-networkd[284]: wlan0: Link DOWN
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Unregistered 'uim' client with ID '2'
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Releasing 'wms' client with flags 'release-cid'...
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Unregistered 'wms' client with ID '1'
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Unregistered 'wds' client with ID '17'
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Releasing 'nas' client with flags 'release-cid'...
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Unregistered 'nas' client with ID '3'
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Releasing 'dms' client with flags 'release-cid'...
Aug 05 20:34:41 mobian NetworkManager[405]: <info>  [1628188481.7597] device (wlan0): set-hw-addr: reset MAC address to 02:BA:36:56:60:D9 (unmanage)
Aug 05 20:34:41 mobian ModemManager[488]: [/dev/cdc-wdm0] Unregistered 'dms' client with ID '1'
Aug 05 20:34:41 mobian systemd-networkd[284]: wlan0: Link UP
Aug 05 20:34:41 mobian NetworkManager[405]: <info>  [1628188481.7850] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Aug 05 20:34:41 mobian NetworkManager[405]: <info>  [1628188481.7866] manager: NetworkManager state is now ASLEEP
Aug 05 20:34:41 mobian NetworkManager[405]: <info>  [1628188481.7879] device (cdc-wdm0): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Aug 05 20:34:41 mobian systemd-networkd[284]: wwan0: Link DOWN
Aug 05 20:34:41 mobian systemd-networkd[284]: wwan0: Lost carrier
Aug 05 20:34:41 mobian wpa_supplicant[422]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Aug 05 20:34:41 mobian dbus-daemon[403]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.15' (uid=0 pid=405 comm="/usr/sbin/NetworkManager --no-daemon ")
Aug 05 20:34:41 mobian NetworkManager[405]: <warn>  [1628188481.9505] modem-broadband[cdc-wdm0]: failed to disconnect modem: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.freedesktop.ModemManager1.Modem.Simple” on object at path /org/freedesktop/ModemManager1/Modem/1
This is the end of the logs. The line before this block was 5 seconds earlier so I assume less relevant. What is interesting is that in the last second of the log I get:
Could it be that somehow crust fails ?
I will try other OSes this weekend.
RE: Pinephone quickly crashes unless plugged to power - by gab - 08-05-2021, 01:07 PM
  Pinephone boot. Richy_T 2 66 Yesterday, 11:52 PM
Last Post: zetabeta
  PinePhone - boot from microSD laserpyramid 9 838 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 419 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 283 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,699 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,919 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 660 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,496 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 537 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,780 12-22-2023, 03:44 PM
