PinePhone won't turn on
I have a Pinephone Beta Edition that shipped on May 26, 2021. It was working fine until a couple weeks ago when it began doing this.
I had the Manjaro/Plasma Mobile that it shipped with, plus I had Mobian/Phosh booting from an SD card. I didn't even use it all that much, because Bluetooth headset is kind of important for me day to day, which does not work for phone calls.
I was updating the Manjaro install when it quit. I think it was rebooting after updating, but I'm not certain. Now I cannot turn it on with the battery installed and USB disconnected.
With or without the battery, if I plug in the USB cable, the LED turns on green. After about 5 seconds, the display backlight turns on, screen is blank. At 7 seconds the device appears to shut off. If I press the power button to turn it back on with the USB cable still connected it repeats the same process.
I tried the SD card that was working fine, no difference.
This seems to me to be either:
1. A hardware failure. In which case the best option is probably to replace the board.
2. A BIOS, boot loader problem (I'm not very knowledgeable about this). I'm not sure if an update could have possibly affected this, but the coincidence with the update is suspicious. Nor do I know if this firmware is strictly read-only, or if there is anyway to fix it.
PinePhone won't turn on - by 0xc - 06-29-2021, 01:52 PM
RE: PinePhone won't turn on - by RodneyMyers - 06-30-2021, 05:20 AM
RE: PinePhone won't turn on - by JMoore - 07-04-2021, 05:05 PM
RE: PinePhone won't turn on - by number9 - 10-16-2021, 11:22 AM
RE: PinePhone won't turn on - by slomobile - 11-08-2021, 01:41 PM
RE: PinePhone won't turn on - by teneighty-yvr - 07-10-2022, 11:53 AM
RE: PinePhone won't turn on - by fxc - 09-18-2022, 03:16 PM
  Using Signal on PinePhone in mid-2023? dante404 47 14,489 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,752 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,302 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 564 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,553 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 25,107 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,228 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 103,458 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,082 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,520 10-24-2023, 08:57 AM
