Shame on pinephone
(06-18-2021, 10:29 AM)dooblewoops Wrote: I flashing correctly, with Balena Etcher, i trying with my mac, or my linux computer.
As already mentioned, this may not be the appropriate process for *every* OS you try to flash. Checkout the Pine64 Wiki and copy the instructions there *exactly*.
(06-18-2021, 10:29 AM)dooblewoops Wrote: That same problem, i trying with msdos, fat 32 or ext3/ext4, that same problem. I change micro sd card three time an other,(sandisk) same problem.
You should not be setting the filesystem as far as I'm aware. This makes me think you are flashing a partition rather than the entire disk.
(06-18-2021, 10:29 AM)dooblewoops Wrote: In micro sd card we have not locking, and in linux computer every time i authorize the program ad working as program. Correct no ?
(06-18-2021, 10:29 AM)dooblewoops Wrote: In ubuntu touch when i put to sleeping, impossible i wake up my phone. In mobian impossible i use my cell phone for call, the sound is shrill, and for call a second time it necessary i put off my phone, and restart.
It's not a finished product yet, these things are being actively fixed. If you want a finished product, spend 10x or 20x more on an iPhone.
(06-18-2021, 10:29 AM)dooblewoops Wrote: Ok maybe i flashing bad, but my Pinephone have a kde plasma mobile OS inside, that's not me i have instaled this one. It's original OS, why it's impossible i do update, he tell me "failed to activate service".
Which Country are you trying to perform the updates from? I'm aware for example that China has been known to block package servers (which is how a bunch of Apple developers out there ended up using a rooted library). The fact you are not able to perform the update seems like a networking issue.
(06-18-2021, 10:29 AM)dooblewoops Wrote: With the original OS without sd card ?
With the beta test the automatic test, the first, the more important, it in in red, "EC25 no sim" but the two cards are in their place. Therefore is the socket block sd card, sim card not working.
It could just mean that your sim/carrier combination are not yet supported. Again, it's still a work in progress.
(06-18-2021, 10:29 AM)dooblewoops Wrote: Why the factory dont use the beta test edition at the end checking. How a devices got out with a broken mainboard. I use linux more ten year, i know that is necessary you put sometimes on your hand in the motor. But here it's too much. My phone is new. And for your information i know pmbootstrap and postmarket OS i use that for Samsung, i use ubport-installer for Xiaomi. And that's working ! Not your Pinephone, while is built for that's.
You have not purchased a Samsung phone, you have purchased a work in progress. If you want a phone that "just works", go buy an Android or iOS device.
(06-18-2021, 10:29 AM)dooblewoops Wrote: That's better for the moment buy a second hand devices for 50$, go to orange fox, ubport-installer or pmbootsrap for installing mobian or ubuntu touch. Not buy a Pinephone futhermore your warranty is only 30 days without warranty your phone working correctly. Waouuu how you make a place betwin Android and Mac with that. You use the OS make by Linux, but you have not the philosophy Linux.
Again, PinePhone is nothing like the devices you are comparing it to.
(06-18-2021, 10:29 AM)dooblewoops Wrote: The factory work is juste create one box with screen, put in a free OS create by Linux, and done.
It's incredibly more complicated, you have no idea. Also the factory just flash community images, they don't write or test any software. (They may check some basic functionality, but that is it.)
(06-18-2021, 10:29 AM)dooblewoops Wrote: But where are the quality control? Never? It so expensive?
The sort of quality you are after doesn't exist here yet. This is not a finished product.
Shame on pinephone - by dooblewoops - 06-17-2021, 09:40 AM
RE: Shame on pinephone - by lordnahte2 - 06-17-2021, 11:31 AM
RE: Shame on pinephone - by barray - 06-17-2021, 11:35 AM
RE: Shame on pinephone - by 33YN2 - 06-18-2021, 01:17 AM
RE: Shame on pinephone - by dooblewoops - 06-18-2021, 10:29 AM
RE: Shame on pinephone - by tophneal - 06-18-2021, 02:12 PM
RE: Shame on pinephone - by K_Research - 06-18-2021, 09:15 PM
Solution - by dooblewoops - 06-24-2021, 11:27 AM
RE: Shame on pinephone - by dooblewoops - 06-19-2021, 10:08 AM
RE: Shame on pinephone - by raingloom - 06-20-2021, 01:27 PM
RE: Shame on pinephone - by TRS-80 - 06-21-2021, 01:19 AM
RE: Shame on pinephone - by ryo - 06-24-2021, 06:11 AM
RE: Shame on pinephone - by barray - 06-24-2021, 04:47 PM
RE: Shame on pinephone - by biketool - 06-25-2021, 08:13 AM
RE: Shame on pinephone - by dooblewoops - 06-29-2021, 05:09 PM
RE: Shame on pinephone - by gamerminstrel - 06-29-2021, 09:10 PM
RE: Shame on pinephone - by biketool - 06-30-2021, 05:42 AM
RE: Shame on pinephone - by barray - 06-29-2021, 10:58 PM
RE: Shame on pinephone - by zetabeta - 06-30-2021, 04:47 AM
RE: Shame on pinephone - by zetabeta - 06-30-2021, 10:52 AM
RE: Shame on pinephone - by TRS-80 - 07-06-2021, 10:07 AM
RE: Shame on pinephone - by dooblewoops - 07-20-2021, 10:48 AM
RE: Shame on pinephone - by ryo - 09-03-2021, 01:56 AM
RE: Shame on pinephone - by biketool - 09-03-2021, 08:25 AM
RE: Shame on pinephone - by XLPops - 10-13-2021, 10:13 PM
RE: Shame on pinephone - by ragreenburg - 11-23-2021, 03:22 PM
RE: Shame on pinephone - by gamerminstrel - 10-20-2021, 03:34 PM
RE: Shame on pinephone - by guenther - 11-25-2021, 11:02 AM
RE: Shame on pinephone - by cabbie001 - 10-20-2021, 10:27 AM
RE: Shame on pinephone - by zetabeta - 10-20-2021, 11:56 PM
  eSIM on PinePhone just_a_q 3 2,668 Yesterday, 03:41 PM
Last Post: bam
  Pinephone boot. Richy_T 4 175 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 930 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 460 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 311 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 111,461 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,971 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 698 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,630 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 566 12-26-2023, 02:42 PM
Last Post: shengchieh
