Plasma Mobile "stable" currently broken
The same thing happens if you apply the updates from previous images.
I connected a keyboard through the dock and I saved the `dmesg`, I should have a look at the Journal too, I will do it later.
I think the suspicious output is the following
[    9.355294] WARNING: CPU: 1 PID: 3435 at net/wireless/core.c:902 wiphy_register+0x95c/0x980 [cfg80211]
[    9.355373] Modules linked in: 8723cs(C+) ov5640 hci_uart btrtl btbcm bluetooth cfg80211 crct10dif_ce st_magn_spi st_sensors_spi st_magn_i2c st_magn sun50i_codec_analog ecdh_generic st_sensors_i2c inv_mpu6050_i2c sun8i_adda_pr_regmap ecc st_sensors inv_mpu6050 stk3310 rfkill industrialio_triggered_buffer anx7688 kfifo_buf sun4i_lradc_keys panel_sitronix_st7703 sun8i_codec sun4i_i2s snd_soc_ec25 snd_soc_simple_amplifier snd_soc_simple_card snd_soc_bt_sco snd_soc_simple_card_utils snd_soc_core snd_pcm_dmaengine snd_pcm snd_timer snd i2c_gpio display_connector soundcore leds_sgm3140
[    9.355518] CPU: 1 PID: 3435 Comm: systemd-udevd Tainted: G         C        5.12.9-1-MANJARO-ARM #1
[    9.355528] Hardware name: Pine64 PinePhone (1.2) (DT)
[    9.355533] pstate: 60000005 (nZCv daif -PAN -UAO -TCO BTYPE=--)
[    9.355541] pc : wiphy_register+0x95c/0x980 [cfg80211]
[    9.355569] lr : rtw_cfg80211_dev_res_register+0x2c/0x44 [8723cs]
[    9.356020] sp : ffff800012163790
[    9.356024] x29: ffff800012163790 x28: 0000000000000013
[    9.356034] x27: 0000000000000100 x26: ffff8000112afb40
[    9.356043] x25: ffff80001013b890 x24: 0000000000000051
[    9.356053] x23: ffff800011705000 x22: ffff0000028d5800
[    9.356062] x21: ffff000005268dc0 x20: ffff000002978000
[    9.356072] x19: ffff000002978300 x18: 0000000000000020
[    9.356081] x17: ffff800008f4dcf0 x16: ffff800011720013
[    9.356090] x15: ffff0000052691b8 x14: 0000000000000000
[    9.356099] x13: ffff000005268dc0 x12: ffff000003b30b14
[    9.356108] x11: 0000000000000010 x10: 00000000ffffffbd
[    9.356117] x9 : ffff800008db2bc0 x8 : ffff000002978438
[    9.356127] x7 : 000000007fffffff x6 : 0000000000000005
[    9.356136] x5 : 0000000000000004 x4 : ffff800008f4bc18
[    9.356145] x3 : ffff800008ee9f70 x2 : 0000000000000000
[    9.356154] x1 : 0000000000000000 x0 : 0000000000000000
[    9.356164] Call trace:
[    9.356169]  wiphy_register+0x95c/0x980 [cfg80211]
[    9.356204]  rtw_cfg80211_dev_res_register+0x2c/0x44 [8723cs]
[    9.356472]  rtw_os_ndevs_register+0x24/0x120 [8723cs]
[    9.356700]  rtw_os_ndevs_init+0x3c/0x60 [8723cs]
[    9.356926]  rtw_drv_init+0xcc/0x27c [8723cs]
[    9.357152]  sdio_bus_probe+0xe8/0x1cc
[    9.357168]  really_probe+0xe4/0x4c0
[    9.357182]  driver_probe_device+0x58/0xc0
[    9.357191]  device_driver_attach+0xc0/0xcc
[    9.357200]  __driver_attach+0x84/0x124
[    9.357209]  bus_for_each_dev+0x70/0xc0
[    9.357218]  driver_attach+0x24/0x30
[    9.357226]  bus_add_driver+0x104/0x1ec
[    9.357235]  driver_register+0x78/0x130
[    9.357244]  sdio_register_driver+0x2c/0x40
[    9.357251]  rtw_drv_entry+0x4c/0xa0 [8723cs]
[    9.357477]  do_one_initcall+0x54/0x1bc
[    9.357489]  do_init_module+0x54/0x250
[    9.357501]  load_module+0x1f90/0x25ec
[    9.357509]  __do_sys_init_module+0x1ac/0x220
[    9.357518]  __arm64_sys_init_module+0x1c/0x30
[    9.357527]  el0_svc_common.constprop.0+0x60/0x120
[    9.357537]  do_el0_svc+0x24/0x90
[    9.357545]  el0_svc+0x2c/0x54
[    9.357555]  el0_sync_handler+0x1a4/0x1b0
[    9.357562]  el0_sync+0x180/0x1c0
[    9.357570] ---[ end trace accd80c7d9d341d7 ]---
RE: Plasma Mobile "stable" currently broken - by mouffa - 06-11-2021, 08:28 AM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,626 10-02-2023, 05:07 AM
Last Post: Uturn
  CardDAV / Nextcloud sync broken Uturn 0 700 06-15-2023, 12:41 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,813 03-02-2023, 07:25 PM
  gnome-mobile dev Uturn 1 1,123 02-22-2023, 03:37 AM
Last Post: acrux
  Manjaro plasma-mobile Beta 13 Uturn 13 4,926 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,590 11-22-2022, 05:00 PM
Last Post: Chief
  Disabling screen timeout for plasma mobile rp3 7 7,251 09-05-2022, 03:50 PM
Last Post: christev1
  VPN on Plasma Hobgoblin 1 1,302 08-29-2022, 03:14 AM
Last Post: saddamus
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,499 07-28-2022, 12:40 PM
Last Post: johaennessen
  switch stable or dev release? Uturn 3 2,007 07-17-2022, 01:38 AM
Last Post: shulamy
