Will the Pinephone work with Vodafone in Romania?
(05-26-2021, 07:23 PM)MirceaKitsune Wrote: I can't quite remember or tell if it's a sim card or microsim, hopefully I'll fine either way?
The PinePhone takes the micro-SIM form factor, but the package includes (or at least used to) a nano-SIM to micro-SIM adapter (literally just a piece of plastic that you put your nano-SIM into) but I recall some posts on the forums saying it's a bit crap. A standard-sized SIM card won't fit into the PinePhone  but you may be able to cut away some of the excess plastic to make it into a micro-SIM, some phone stores even offer to do that for you, but I wouldn't recommend that either as you risk damaging the electronics inside the SIM card.
(05-26-2021, 07:23 PM)MirceaKitsune Wrote: So to EU users of the Pinephone, what's your experience with Vodafone SIM cards?
I've had no issues on the Vodafone network in Czechia or Netherlands, nor on the KPN network in the Netherlands (via Simyo MVNO); keep in mind I only tested calls and SMS, I don't use mobile data.
RE: Will the Pinephone work with Vodafone in Romania? - by marcih - 05-30-2021, 07:48 AM
  eSIM on PinePhone just_a_q 4 2,746 Yesterday, 01:35 PM
  Pinephone boot. Richy_T 4 201 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 961 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 475 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 319 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 111,617 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,995 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 707 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,669 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 572 12-26-2023, 02:42 PM
Last Post: shengchieh
