Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else?
You can use "dmesg" to determine if "kernel param" is working properly.
The kernel I'm using is different from "Armbian", but see below for a comparison.
# kernel param: libata.force=6.0Gbps # or "kernel param": none
[    2.853814] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.880750] ata1.00: ATA-8: TOSHIBA MQ01ABD100, AX1P2A, max UDMA/100
[    2.880754] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    2.882527] ata1.00: configured for UDMA/100
[    2.883274] scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA MQ01ABD1 2A   PQ: 0 ANSI: 5
[    2.894956] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    2.894960] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    2.895075] sd 0:0:0:0: [sda] Write Protect is off
[    2.895081] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.895130] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.109635]  sda: sda1 sda2 < sda5 sda6 sda7 sda8 sda9 sda10 sda11 sda12 sda13 sda14 sda15 sda16 >
[    3.136205] sd 0:0:0:0: [sda] Attached SCSI disk
# kernel param: libata.force=3.0Gbps
[    2.365367] ata1: FORCE: PHY spd limit set to 3.0Gbps
[    2.365838] ata1: SATA max UDMA/133 abar m512@0xfa010000 port 0xfa010100 irq 243
[    2.366498] ata2: FORCE: PHY spd limit set to 3.0Gbps
[    2.366953] ata2: SATA max UDMA/133 abar m512@0xfa010000 port 0xfa010180 irq 243
[    2.830294] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[    2.862941] ata1.00: ATA-8: TOSHIBA MQ01ABD100, AX1P2A, max UDMA/100
[    2.862945] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    2.864633] ata1.00: configured for UDMA/100
[    2.865399] scsi 0:0:0:0: Direct-Access     ATA      TOSHIBA MQ01ABD1 2A   PQ: 0 ANSI: 5
[    2.876828] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    2.876832] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    2.876960] sd 0:0:0:0: [sda] Write Protect is off
[    2.876966] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.877022] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.091710]  sda: sda1 sda2 < sda5 sda6 sda7 sda8 sda9 sda10 sda11 sda12 sda13 sda14 sda15 sda16 >
[    3.101514] sd 0:0:0:0: [sda] Attached SCSI disk
If your settings are working as expected and you still can't see any improvements ...
  There is also "force to PCIE-GEN1", but I don't think it's likely to improve.
If all you can think of doesn't work, unfortunately you have to give up.
In my opinion, "PINE's SATA-Card" is a card of that degree after all.
A similar problem occurred when I installed this "SATA-Card" on a standard "x86-Base PC".
Therefore, it is not a problem limited to Arm-based SBC.
I think the quality of this card itself is poor.
--- Addition ---
ASM1061 vs ASM1062
# lspci
00:00.0 PCI bridge: Fuzhou Rockchip Electronics Co., Ltd Device 0024
01:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 01)
It's just a matter of recognition.
The above "SATA-Card" was purchased from "PINE-Store" and the Chip stamp is "ASM1061".
But, "lspci" reports "ASM1062" as mentioned above.
RE: Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? - by t4_4t - 05-20-2021, 05:22 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 696 03-25-2024, 12:12 PM
  RK3399 PCIe enumeration jhadd 0 320 01-31-2024, 08:56 AM
Last Post: jhadd
  yocto for RockPro64 Fide 1 786 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,745 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 18,010 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 84,567 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 636 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 1,028 03-12-2023, 06:55 PM
Last Post: quixoticgeek
Question nand-sata-install on RAID-1 array ARMandHammer 1 942 02-12-2023, 03:10 AM
Last Post: igorp
  RockPro64 boot questions misterc 3 1,699 01-13-2023, 06:21 PM
Last Post: misterc
