WARNING to future users ~ Order yourself a SIM Card Extender
(05-02-2021, 08:35 AM)Bonesdog Wrote: If you recently ordered a PinePhone64 I highly suggest you order yourself a better SIM Card Extender.
Under no conditions should you even ATTEMPT to use the plastic one sent with the device. Iv personally verified it Will break the Sim Card Slot due to how the extender is designed (Cheap plastic, rough edges catch on prongs)
One does have to be careful. Not all sims will hold snugly in the plastic adapter. I find it may help to put slight finger pressure over top of it as you slide it in to prevent the SIM from slipping out (and possibly catching pin).
Martijn Braam did a video covering inserting sim cards into Pinephone: https://youtu.be/SiQSJSrPqd8. The one some users have issue with is the nano sim found at 2:57 in the video.
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
RE: WARNING to future users ~ Order yourself a SIM Card Extender - by RTP - 05-02-2021, 12:19 PM
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 24,374 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 3,504 05-25-2022, 03:26 PM
Last Post: sfb
  Any UK Pinephone users making telephone calls? GrapeJuice 4 3,167 01-24-2022, 04:37 PM
Last Post: dukla2000
  Largest supported micro SD card? zooidic 2 2,055 01-08-2022, 06:01 AM
Last Post: zooidic
  Red LED when trying to boot from SD card. Need advice. サーバント 5 4,301 10-20-2021, 09:40 AM
  Fragile SIM card connector hakkou 1 1,844 08-25-2021, 07:44 AM
Last Post: wibble
  Sd card slot death? Hurrikan 7 6,635 05-17-2021, 03:55 PM
Last Post: jrballesteros05
  Future plans for hardware daniel_mazurkiewicz 10 11,061 04-09-2021, 01:52 AM
Last Post: nilclara
  Strange SD Card Problems anhilde 7 6,468 02-21-2021, 07:52 AM
  Fastest SD card happybot-4678 9 8,679 02-20-2021, 01:08 AM
Last Post: dsimic
