06-14-2016, 12:26 AM
(06-13-2016, 03:39 PM)g_t_j Wrote: Hi there.
Very interesting post.
I got 2 pines out of 4 which refuse to connect to anything on the internet on Android/Remix while are very slow on Linux.
I also get the same results as you on Android with these 2 boards. They do connect to a time server, get an IP from the router, the LAN leds blink constantly, everything seems OK BUT... they don't connect to anything!
I will try the WIFI module with these boards tomorrow. I will set up a wireless connection and then with the WIFI still switched on, I will connect an Ethernet cable and give the board some time.
Will post back if anything changed. Hope you found the solution to the problem. If that's the case, then it's probably the quality of the Ethernet driver that causes the issue.
Yes that would be the case. It was also my thought and that was reason why i posted all this. I tried to narrow it down as much as it was possible for me with my expirience. But as you can see it has it's limitations.
I hope it get's fixed with some updates, if that's the case then PINE64 just needs to Upload a new Image for Android with the Updates included
