Back cover plastic woes
(03-27-2021, 06:20 AM)mteagles1942 Wrote:
(03-27-2021, 01:20 AM)dgdimick Wrote:
(03-22-2021, 08:29 AM)mteagles1942 Wrote: I finally received my phone and the second day I apparently snapped the thin plastic in between the volume and power buttons.  When the back cover was removed the buttons fell off.  With a careful hand I was able to put it back together and buttons are working, however now I am afraid to take the cover off again when needed.
I could go on blah blah.  My only question is does anyone know of a ETA on back cover https://pine64.com/product/pinephone-bac...46c16e2e66  availability?
thanks everybody
There's a STL that will allow you to print a replacement cover your self.
Where are you located, maybe I can print one for you and ship it to you?
Hello and thank you for your reply.  I am in WA state (USA) if that helps.  I will totally pay you for your trouble and the shipping!  If you are able to I'd take 2 or 3 even!!  3D printing is so cool Smile   I am also confused about the power / volume buttons.  Are they a part of the back cover?  Or part of the phone?  When they fell off there is no apparent place to attach them,  they just sit in the plastic holes (once cover is attached they work).  Just have to be very careful and patient when replacing the cover.................maybe super glue?  Anyone else experience problems with the buttons falling off?
I'm in New Mexico, so getting them to you should be fairly easy.
It'll take a small amount of time before I can print them up, I've got a few jobs currently in the Que, as well as I need to try and print one first. It looks like it shouldn't be an issue, however, you never know with 3d Printed stuff. Some days things just suck.
To answer the button question, yes, they just lay in the case, so every time you open the case your going to have to watch for them getting lost.
As for what it will cost, normally I only charge $1 an hour to print 3d designs that are open source, so the cost for each would be about $9 or so, then USPS shipping is about $10. Printing a few for you shouldn't be a problem.
I'm not sure what color filament I currently have, since I'll want to use PETG or ABS filament, PLA, the most common filament doesn't hold up to the heat the PinePhone puts out, as well as just sitting in the Sun light can cause it to warp.
Send me a PM so I don't forget about you, and if you don't hear from me in a week or so ping me again.
Back cover plastic woes - by mteagles1942 - 03-22-2021, 08:29 AM
RE: Back cover plastic woes - by dgdimick - 03-27-2021, 01:20 AM
RE: Back cover plastic woes - by mteagles1942 - 03-27-2021, 06:20 AM
RE: Back cover plastic woes - by dgdimick - 03-27-2021, 06:35 AM
RE: Back cover plastic woes - by Mtravel - 03-28-2021, 02:26 PM
RE: Back cover plastic woes - by dgdimick - 03-28-2021, 06:19 PM
RE: Back cover plastic woes - by NormandC - 03-28-2021, 10:19 PM
Question Alternative Designs or Materials for the Back Cover? BMayes 2 578 12-18-2023, 11:19 AM
Last Post: BMayes
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,361 10-12-2023, 01:03 PM
Last Post: robthebold
  UV stabilised/resistant plastic? cmicallef 2 2,134 11-14-2021, 11:13 PM
Last Post: cmicallef
  Connection woes, modem troubleshooting within Bewilderforce 0 1,344 10-06-2021, 04:02 AM
Last Post: Bewilderforce
  Back cover with UBPorts logo cracked Phillip Bell 7 6,917 03-22-2021, 12:20 PM
Last Post: mteagles1942
Question Approximate leadtime for when the 3GB/32GB mainboard is back in stock? NormandC 2 3,115 12-15-2020, 10:29 PM
Last Post: NormandC
  Could information be printed on the inside back cover? desca 0 1,389 10-21-2020, 02:15 PM
Last Post: desca
Bug USB Type-C connector overmold conflicts with the back cover ngkz 1 2,886 05-10-2020, 12:19 AM
