C GPIO
hi, I just did some testing with Pine GPIO68 [ pin 32, GPIO12 ] ...
... again, try using 0x44 in your C code ( the hex number for GPIO 68 ).  I verified that GPIO68 works well for IN | OUT , defaults to 0 , and drives standard LED brightly with the normal 330 ohm limiting resistor.  I have my LED plugged into the lab board at GPIO12, on pin(32); however, I'm driving the output with sysfs using Pine GPIO68 !
The following code is a bash script that will blink the Pine GPIO68 [ pin 32, GPIO12 ] line seven times:
Put the script in a file, chmod it with 0754, and run with sudo ./blink.sh
blink.sh
#!/bin/sh
echo 68  > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio68/direction
for i in `seq 1 7`
do
   echo 1 > /sys/class/gpio/gpio68/value
   sleep .35
   echo 0 > /sys/class/gpio/gpio68/value
   sleep .65
done
echo 68  > /sys/class/gpio/unexport
hope this helps you
C GPIO - by igna09 - 06-10-2016, 12:41 PM
RE: C GPIO - by martinayotte - 06-10-2016, 01:52 PM
RE: C GPIO - by igna09 - 06-10-2016, 02:16 PM
RE: C GPIO - by martinayotte - 06-10-2016, 03:10 PM
RE: C GPIO - by martind1983 - 08-24-2016, 09:55 AM
RE: C GPIO - by igna09 - 06-11-2016, 02:51 AM
RE: C GPIO - by martinayotte - 08-25-2016, 07:35 AM
RE: C GPIO - by martind1983 - 08-25-2016, 08:24 AM
RE: C GPIO - by MarkHaysHarris777 - 08-25-2016, 11:17 AM
RE: C GPIO - by martind1983 - 08-29-2016, 01:30 AM
RE: C GPIO - by martind1983 - 08-29-2016, 03:50 AM
RE: C GPIO - by MarkHaysHarris777 - 08-29-2016, 05:25 AM
RE: C GPIO - by martind1983 - 08-31-2016, 03:47 AM
RE: C GPIO - by pfeerick - 08-31-2016, 04:14 AM
RE: C GPIO - by martind1983 - 08-31-2016, 04:36 AM
RE: C GPIO - by MarkHaysHarris777 - 08-29-2016, 05:04 PM
RE: C GPIO - by MarkHaysHarris777 - 08-31-2016, 04:09 AM
RE: C GPIO - by KnReLe - 08-31-2016, 07:27 AM
RE: C GPIO - by martind1983 - 09-01-2016, 05:08 AM
RE: C GPIO - by MarkHaysHarris777 - 09-01-2016, 05:29 AM
RE: C GPIO - by martind1983 - 09-01-2016, 08:04 AM
RE: C GPIO - by KnReLe - 09-01-2016, 08:52 AM
RE: C GPIO - by martind1983 - 09-01-2016, 09:06 AM
  RPi.GPIO python module for Pine A64/A64+ aquilegia 97 133,401 02-23-2022, 02:56 PM
Last Post: ncs
  fm transmitter with gpio weasel18 2 4,884 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 3,634 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 11,248 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 11,332 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 11,953 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 31,972 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 14,915 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 21,407 08-17-2017, 01:21 PM
Last Post: martinayotte
  GPIO fiq capability joseph 3 6,163 11-10-2016, 06:07 PM
Last Post: joseph
