KDE Keyboard -- CTRL / ALT keys in Konsole
(02-21-2021, 08:59 AM)MtnSk8 Wrote: Hi, I'd like to exit/save a document in Nano but the Plasmanjaro keyboard won't allow it.  Can I use something like xdotool and set a "quick action" in qmlKonsole that sends the Ctrl-x key combo?
@MtnSk8
I was slightly puzzled by the qmlkonsole virtual keyboard having just installed Manjaro Plasma Mobile - I've been using Mobian for a while now.
I just noticed that the top 'bar' scrolls left and right with Ctrl Alt Esc Tab etc keys just after the Hamburger.
I just pressed Ctrl and it stays highlighted until you press it again, so it should work as expected...
Ha ha ha, I just tried it and it does not work, see this bug report
https://gitlab.manjaro.org/manjaro-arm/i.../issues/23
I tried the Actions but that didn't work either , it just pastes the text in nano....
I guess we have to wait for coders to bug fix eventually.
I think a lot of us just SSH from our laptop / desktop, that makes things a lot easier.
If you're on the move, though, I agree you'd expect the virtual keyboard to work.
I'm sure the commit will be merged into master and we'll get the update at some stage, hopefully soon.
RE: KDE Keyboard -- CTRL / ALT keys in Konsole - by dcinoz - 02-21-2021, 10:46 PM
  No keyboard in Signal Desktop Kimberley van Buyten 4 2,383 10-16-2022, 10:25 AM
Last Post: Eugo
  Where do the keyboard layouts go? Eugo 1 1,102 08-31-2022, 11:03 AM
Last Post: Eugo
Sad Latest Manjaro breaks Keyboard Case (Again)? hollerpots 4 2,775 06-17-2022, 07:48 AM
Last Post: hollerpots
  Vivaldi Browser doesn't start keyboard for text entry tckosvic 1 2,014 05-24-2022, 11:32 PM
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,071 05-09-2022, 08:29 AM
Last Post: ragreenburg
  Keyboard case stopped working on pacman update rotwang 5 3,167 05-07-2022, 09:17 PM
Last Post: rotwang
  Ctrl-O on virtual keyboard not working in nano PJK2012 3 3,174 11-11-2021, 08:47 PM
Last Post: PJK2012
  open on-screen keyboard at will yogo1212 2 2,897 06-12-2021, 06:15 PM
Last Post: ryo
  How to close app when using dock/mouse/keyboard/ext display? alx27 0 1,253 05-27-2021, 06:09 AM
Last Post: alx27
  How to disable vibration feedback on the touch keyboard? punchy88 0 1,727 11-26-2020, 02:15 PM
Last Post: punchy88
