Wake up from charging problem
(02-19-2021, 07:35 PM)C0ffeeFreak Wrote:
(02-19-2021, 02:36 PM)j4n3z Wrote:
(02-19-2021, 09:33 AM)Gribouille Wrote:
(02-18-2021, 11:31 PM)j4n3z Wrote: Update:
After few reboots yesterday the phone refused to boot again. Stuck on green LED light.
So I downloaded and flashed to eMMC a newest image - mobian-pinephone-phosh-20210216.img and tried again - this did not solve the charging problem though.
In the case of 'green led', you can try to remove the battery, for me it's working.
Yeah, I did this several times before. This time no change after several battery removals and waiting for about 5min average. Reflashing system solved green light problem but I am still unable to solve the main issue - Mobian does not wake up after full charging over night.
Have you updated the latest modem manege and phone app upgrades that rolled out on the 18th?
Run the updates through the terminal and don't let your phone screen lock when the updates are installing. Keep tapping on the terminal screen will work.
sudo apt update
sudo apt dist-upgrade
sudo apt autoremove
Yesterday as I was responding the system was up to date. Now I did these commands again and upgraded 3 packages.
However I am not sure which of these should solve the problem?
libselinux:arm64
libfuse3-3:arm64
man-db:arm64
fuse3:arm64
libmalcontent-ui-0-0:arm64
libmalcontent-0-0:arm64
libopenjp2-7:arm64
These should be everything according to apt log which were upgraded since last charging over night. I will try to perform full charge again ASAP.
Wake up from charging problem - by j4n3z - 02-18-2021, 02:23 AM
RE: Wake up from charging problem - by j4n3z - 02-18-2021, 11:31 PM
RE: Wake up from charging problem - by Gribouille - 02-19-2021, 09:33 AM
RE: Wake up from charging problem - by j4n3z - 02-19-2021, 02:36 PM
RE: Wake up from charging problem - by j4n3z - 02-20-2021, 02:11 AM
RE: Wake up from charging problem - by j4n3z - 02-21-2021, 05:17 AM
RE: Wake up from charging problem - by scholbert - 02-21-2021, 10:12 AM
RE: Wake up from charging problem - by spaetz - 02-21-2021, 10:35 AM
RE: Wake up from charging problem - by j4n3z - 02-22-2021, 01:02 AM
RE: Wake up from charging problem - by scholbert - 02-22-2021, 03:08 PM
RE: Wake up from charging problem - by j4n3z - 02-25-2021, 03:53 PM
  Unable to wake up from suspend xavi92 5 1,174 10-26-2023, 03:02 PM
Last Post: xavi92
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,541 08-31-2023, 12:38 PM
Last Post: vusra
  MODEM - Usb problem & couldn't query SIM slots: QMI protocol freelectro 5 2,894 06-06-2023, 06:36 AM
Last Post: freelectro
  Best way to wake up and check emails? DrPlamsa 7 5,634 12-31-2022, 10:57 AM
Last Post: DrPlamsa
  Does tow-boot allow periodic wake from suspension to check for notifications? DrPlamsa 4 2,705 12-31-2022, 10:56 AM
Last Post: DrPlamsa
  Is there a smart-wake yet? DrPlamsa 6 2,439 12-31-2022, 10:55 AM
Last Post: DrPlamsa
  Battery problem with a Pinephone keyboard and Mobian elode 2 2,229 12-22-2022, 07:10 PM
Last Post: acid andy
  Problem updating gilwood 5 3,336 06-09-2022, 08:27 AM
Last Post: gilwood
  Gnome Web CSS problem? jojuma 0 829 05-27-2022, 11:43 AM
Last Post: jojuma
  Problem with wifi kubussz 0 887 04-02-2022, 12:57 PM
Last Post: kubussz
