Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted!
(11-05-2021, 12:38 AM)NephreNeko Wrote: MMSD-TNG consistently reports "failed to handle incoming notification" regardless of OS or branch of mmsd-tng and chatty. Inspecting mmsd-tng shows that it "recieved SMS WAP", lists service data and len, shows "about to push notify", lists a pdu and len, and then lists a "mms_service_push_notify() followed by a series of dozens of capitalized numbers and letters, and then finally states mmsd-tng[4351] failed to handle incoming notification, which is what I presume is holding my phone back from receiving/sending MMS.
I use ModemManager, Verizon, mmsd-tng, chatty, and do not use Ofono.
Hey, not sure if you've tried again recently since you posted this, but the issues with Verizon should be fixed. Also, as I'm also on Verizon, I had to set ForceCAres = true. Not sure if you'll have to, but it worked for me.
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,650 10-18-2023, 08:37 AM
Last Post: luppivega
  A/B testing or Unit testing gulshan212 0 1,021 08-29-2023, 03:36 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 1,638 04-10-2023, 10:19 PM
Last Post: lupyuen
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 3,131 04-09-2023, 06:08 PM
Last Post: zetabeta
Sad Modem is always visible/connected but stops working after a while dante404 6 3,241 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 2,733 10-25-2022, 05:28 PM
  Pinephone: OpenGL support? orbital 2 2,282 08-25-2022, 04:09 PM
Last Post: vortex
  Latest firmware for PinePhone modem! Subsentient 104 131,670 07-20-2022, 05:32 AM
Last Post: zetabeta
  Which PP OS currently has the best podcast support? kujo_marble 3 2,146 07-14-2022, 07:09 AM
  Help wanted: location of calls and chatty data files dukla2000 3 4,744 06-13-2022, 02:01 PM
Last Post: israel
