pbp no longer boots
(12-01-2020, 03:21 PM)tulsums Wrote:
(12-01-2020, 01:31 PM)tophneal Wrote: sounds like the battery was drained all the way. Leave it charging for the better part of a day. (It's slow to fully recharge. from dead-dead, it can take about 8 hours to get to 30-50%, but that should be enough to boot it again.)
since sleep only works (okay-ish at that) with bsp uboot, it's probably wise to make it habit to shutdown your pbp after use, or make sure it's plugged in to charge.)
mmm okay thanks. I will keep it on the charger for a while. I did try to disconnect the battery and connect the by pass cables to start from just the power cable. it didn't boot. Would that rule out your theory?
another detail. it's still charging. if I short press (2 sec)  the power button the power led will turn amber for maybe 10 second then green for 1 or 2 then off. no boot.
pbp no longer boots - by tulsums - 12-01-2020, 11:12 AM
RE: pbp no longer boots - by tophneal - 12-01-2020, 01:31 PM
RE: pbp no longer boots - by tulsums - 12-01-2020, 03:21 PM
RE: pbp no longer boots - by tulsums - 12-01-2020, 06:58 PM
RE: pbp no longer boots - by tophneal - 12-02-2020, 07:59 AM
RE: pbp no longer boots - by xyzzy - 12-02-2020, 02:07 PM
RE: pbp no longer boots - by KC9UDX - 12-01-2020, 08:56 PM
pbp no longer boots - by tophneal - 12-02-2020, 02:41 PM
RE: pbp no longer boots - by tulsums - 12-02-2020, 03:16 PM
RE: pbp no longer boots - by wdt - 12-02-2020, 06:36 PM
RE: pbp no longer boots - by tulsums - 12-03-2020, 08:16 AM
RE: pbp no longer boots - by xyzzy - 12-02-2020, 09:53 PM
RE: pbp no longer boots - by wdt - 12-03-2020, 11:29 AM
  Pinebook pro no longer boots xsquared93 7 7,524 02-13-2021, 09:39 AM
Shocked My pbp no longer boots sunjam 2 3,101 12-02-2020, 11:05 PM
Last Post: sunjam
  New Pinebook Pro, only boots 50% of the time micnd90 8 7,840 09-08-2020, 01:25 PM
Exclamation [SOLVED] PBP will no longer power on s3rvant 10 10,294 07-04-2020, 01:57 PM
Last Post: prokofiev
  emmc boots intermittently? haziz 7 7,296 06-08-2020, 07:22 PM
Last Post: mammbo3
