Is there a temperature sensor on Pine?
(06-05-2016, 03:31 AM)longsleep Wrote: To sum this up, without a fan it is impossible to keep below 80*C, with a good heatsink and fan the SoC temperature can stay at around 70*C at maximum speed heavy load (at 23*C ambient temperature).
One more thing not mentioned often enough. Doing any heavy load on the Pine64 will require a stable power supply which is almost impossible to get using micro USB powering. So if your board shuts of or freezes and you think it is the heat it most likely is not - you just got under voltage due to crappy power supply setup.
I'd just like to add that it is quite informative watching your pine64_health.sh running (with the -w) flag when the pine64 is under load... ran stress on mine for several minutes flogging all the CPU cores, disk and memory I/O, and was able to see the CPU throttling to keep the core temp below 90*C (at 26*C ambient atm).
Also, it is more often the MicroUSB lead that is the culprit, more often than the power supply (in my experience anyway... then again, I use 2.4A and 5A/10A rated PSUs, some tweaked to 5.2v Smile ). I have a load of microUSB cables that are either charge only (so no data wires, which is handy when you want to plug your phone in to get a file of it...) or just plain pathetic, they are useless for anything over 1A load (which is probably being too generous... more like 500ma). There is too much resistance in the wire & connector leading to warm cabling and voltage sag, and an unhappy pine64 if it gets loaded up.
Hm... I wonder how well you could overclock the pine64 it it were installed in a fridge... internet connected fridge anyone?
RE: Is there a temperature sensor on Pine? - by pfeerick - 06-05-2016, 06:13 PM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,653 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 625 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 4,007 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 6,026 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,370 02-09-2021, 12:17 AM
Question A64 TDP / max CPU temperature grobbs 3 4,827 02-02-2021, 04:35 AM
Last Post: barray
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 4,534 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 7,835 12-06-2020, 03:53 PM
Last Post: junkyj753
  Node Red on the Pine DonFL 0 2,796 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 3,263 12-02-2019, 09:36 PM
Last Post: netHolio
