Latest firmware for PinePhone modem!
#59
I flashed 01.003.01.003. After completion and the programmed modem reset I restarted the phone and made one outgoing test call and one inbound test call successfully. Then I let the phone go to sleep and tried another inbound call. The phone never rang or came out of sleep. When I pushed the power button to wake up the phone, the modem had crashed (no mobile annunciation on the top status strip and no modem in the Setting ap, etc.
As usually a phone reset brought the modem back to life and I restored the following settings that had changed after flashing the new firmware to match their values before I had flashed 01.003.01.003.
< lines are original settings
> lines are post flash settings, which I wrote over to match original settings.
< response: '+QCFG: "wakeupin/level",0'
> response: '+QCFG: "wakeupin/level",0,0'
11c11
< response: '+QCFG: "ModemRstLevel",0'
> response: '+QCFG: "ModemRstLevel",1'
13c13
< response: '+QCFG: "airplanecontrol",1,0'
> response: '+QCFG: "airplanecontrol",0,0'
Next I tried another inbound call to my sleeping pinephone. It rang on the third outbound phone ring tone and the call was completed successfully.
However, I've now had a second crash of the modem while testing to see if the GPS would function (it usually doesn't function), resulting in a loss of the modem from the system again and another phone reset was required to restore modem functionality. This is a problem that has always plagued my phone, but these two failures were within only about 20 minutes of use, which is an exceptionally poor failure rate. It usually only happens every few days or even only after a week or two.
I'll use 01.003.01.003. for a while and then I'll try 01.002.01.002.
Finally, though certainly convenient, the lack of enforcement of the requirement to use the test points or ADB is strange. Perhaps it's some kind of security feature bug?
RE: Latest firmware for PinePhone modem! - by calinb - 08-11-2021, 10:34 PM
  Movuan distribution for PinePhone merom 5 4,688 07-27-2025, 05:01 PM
Last Post: merom
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,040 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 54,067 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 4,305 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 58,537 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 5,604 07-04-2024, 07:34 AM
  Which word processor to choose for the Pinephone? Peter Gamma 16 14,890 06-22-2024, 07:28 AM
  Samba share on the Pinephone? Peter Gamma 0 3,790 06-16-2024, 10:26 PM
  Possible Free Backup Carrier for PinePhone PineFone 0 3,683 06-13-2024, 03:45 PM
Last Post: PineFone
  Using Signal on PinePhone in mid-2023? dante404 47 45,147 05-03-2024, 02:19 AM
Last Post: dragonhospital
