PineA64 512 reboot - board shut down
I got the backed pine64 512, pretty exited tried to boot using the Debian image provided but no success with all the attempts
1. Used 5V 2amp adapator with cable the Red led goes of after some time
2. Changed cables as per the support from luke and bought 24 AWG cable the board keeps rebooting for couple of times and shuts down completely
3. The power management IC heats up like its going to blow up, but good it has the functionality of shutting down crossing certain temperature ..
4. Strongly feel there is an hardware issue with the 512 what I have received and nothing to do with the power when it is able to boot up Pi3 with the same adaptor
5. tried with 65 and 101 images, no results even after multiple booting
6. no other peripherals connected, still no success
7. Connected only ethernet, but still no success with same results
8. Have checked the serial output during boot it stops at cooling the cpu and shuts down with RED LED going off
can somebody suggest or help here to resolve the issue
PineA64 512 reboot - board shut down - by indrajith - 05-26-2016, 09:21 AM
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,606 10-06-2022, 08:46 PM
Last Post: ihab
  PSCI, u-boot and reboot on Sopine ClusterBoard hbaxmann 0 2,357 09-03-2019, 11:57 PM
Last Post: hbaxmann
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 15,632 05-15-2019, 02:55 PM
Last Post: Thatoo
  Any success working with OpenCV on the PineA64? Tonny91 0 2,476 10-16-2018, 09:16 PM
Last Post: Tonny91
  My first Single Board! jjh221 4 6,833 04-09-2018, 06:52 PM
Last Post: jjh221
  sopine cluster board install Smurfbot 1 4,438 03-31-2018, 04:09 AM
Last Post: pfeerick
  What is the format that one should use for imaging SD cards on APINE64+2GB Board? Doryan 1 3,553 03-05-2018, 08:11 PM
  Which board to use? Dayve 0 2,304 02-18-2018, 06:31 AM
Last Post: Dayve
  Kodi on Rock64 board cenguix 2 8,899 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
  What are these pins on PIN board? dims 1 3,274 01-15-2018, 11:21 AM
Last Post: Luke
