Pinephone inner frame fused to motherboard?
(09-29-2020, 04:47 AM)wibble Wrote: I think there's a clip there, similar to the ones around the edges. There was no glue, and no need to heat, when I took mine apart. If you want to remove the main board that's a tight fit too.
@wibble thanks for the info. I did try some tentative prying/pulling with a small screwdriver. I'll get a bit more physical and try again. Gluewise I thought some could have migrated from the original battery transport insulation tab, as the phone got quite hot the glue might have set harder then intended.
RE: Pinephone inner frame fused to motherboard. - by --- - 09-29-2020, 05:46 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 2 251 07-09-2025, 02:04 PM
Last Post: georgegohl888
  Modem Issues with the Pinephone Temmie19 5 1,601 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 1,070 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone + Keyboard for sale, little use ruemoo 9 2,758 06-10-2025, 09:25 PM
Last Post: skaffi
  Pinephone not booting sd card... bruv 1 701 03-25-2025, 08:51 PM
  Pinephone - broken power button rorus 13 14,433 12-16-2024, 08:32 PM
  various tricks to open the pinephone shengchieh 3 2,385 09-16-2024, 03:42 AM
  my pinephone melted norayr 6 3,568 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 2,303 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 1,884 03-21-2024, 08:52 AM
Last Post: unrznbl
