read-only boot partition?
(09-16-2020, 10:06 PM)wdt Wrote: 4.4.207?? You didn't get most up to date on git,, 4.4.210,, and the (mrfixit) updates to 4.4.213
(ls /lib/modules)
That update is an icon just left of clock, bottom right (logged in as root)
If you added a user, it (icon) may not be there (also updates & writes u-boot)
/usr/bin/mrfixit_update.sh (as root,, it will modify extlinux.conf too)
BTW, extlinux has NOTHING to do with syslinux, just the same name
I don't think you want (or should) use a stock debian kernel,
it lacks pbp specific patches
You know kernel is 64 bit,, userland armhf (32 bit)?? (mrfixit distro)
yup, 4.4.207. only updating I ever did here was the "standard" routes (apt-get update / upgrade / dist-upgrade), so i guess I missed that. (and I made a new user right away so I guess i never saw the updates icon, thanks for pointing that out).
ls /lib/modules:
4.4.207  5.8.0-1-armmp 5.8.0-1-armmp-lpae
(5.8.0-1 is what I apt-get installed manually per here, but clearly i'm not using it)
I found mrfixit_update.sh in /usr/bin just now, thank you! I was looking for it before but I never found it so i thought "hey maybe there's something different about the stock vs unofficial etc". i'll give that a poke and post back.
thanks for your help!
read-only boot partition? - by tpchuckles - 09-16-2020, 07:29 PM
RE: read-only boot partition? - by wdt - 09-16-2020, 10:06 PM
RE: read-only boot partition? - by tpchuckles - 09-17-2020, 06:37 AM
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,207 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 1,227 11-23-2023, 07:37 AM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,967 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Emergency Mode Boot Hotkey? jiacovelli 20 4,413 06-02-2023, 01:32 PM
  Tow Boot install help Paulie420 7 3,748 11-24-2022, 10:24 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 1,972 10-31-2022, 10:14 AM
  Bootloader: SD card boot quirks crazyquark 1 1,067 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Fresh Manjaro does not boot from eMMC pentamassiv 7 4,520 08-18-2022, 11:47 AM
Last Post: Bemo
  PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD Pino64 21 10,293 05-12-2022, 05:00 AM
Last Post: Pino64
  Broken eMMC boot annahellrothsparent 3 2,447 04-28-2022, 07:31 AM
