Arch Linux ARM on PineTab 1
(09-13-2020, 09:40 AM)Danct12 Wrote: Arch Linux ARM (20200913):
  • First image release for the PineTab Early Adopter devices!
  • Audio support for PineTab
  • Fixed camera on PineTab
  • Calls now inhibit suspend (no more unintended suspend while talking!)
  • Callback button has been added, now missed calls can be called through notifications.
  • Fixed Wi-Fi hotspot
  • Haptic feedback for keyboard
https://github.com/dreemurrs-embedded/Pi...g/20200913
Thank you for your work on this! At first I thought the image wouldn't boot, but I accidentally flashed the Pinephone image. Now that I have the correct image, it is working very well. The sound control is fairly good without having to dig into the terminal with alsamixer. I used a USB headset-works fab. Using the 3,5 mm audio jack didn't work..but I didn't feel up to fiddling with it since the sound on the USB headset is better anyway. Overall, one of the best out images available. Thanks again!
Arch Linux ARM on PineTab 1 - by Danct12 - 09-10-2020, 08:33 PM
RE: Arch Linux ARM on PineTab - by barray - 09-11-2020, 10:41 PM
RE: Arch Linux ARM on PineTab - by wd5gnr - 09-12-2020, 03:57 PM
RE: Arch Linux ARM on PineTab - by pjsf - 09-12-2020, 05:38 PM
RE: Arch Linux ARM on PineTab - by wispoffates - 09-13-2020, 12:11 AM
RE: Arch Linux ARM on PineTab - by Danct12 - 09-13-2020, 09:40 AM
RE: Arch Linux ARM on PineTab - by wd5gnr - 09-13-2020, 03:05 PM
RE: Arch Linux ARM on PineTab - by ImaPagan - 09-13-2020, 03:08 PM
RE: Arch Linux ARM on PineTab - by BlueGalaxy - 05-14-2023, 06:54 PM
RE: Arch Linux ARM on PineTab - by aqtrans - 09-13-2020, 02:41 PM
RE: Arch Linux ARM on PineTab - by Danct12 - 09-14-2020, 08:20 PM
RE: Arch Linux ARM on PineTab - by ImaPagan - 09-14-2020, 11:00 PM
RE: Arch Linux ARM on PineTab - by wd5gnr - 09-15-2020, 03:28 PM
RE: Arch Linux ARM on PineTab - by SpoofyKid - 09-15-2020, 05:05 PM
RE: Arch Linux ARM on PineTab - by Danct12 - 09-17-2020, 02:00 AM
RE: Arch Linux ARM on PineTab - by kelbot - 09-26-2020, 08:27 PM
RE: Arch Linux ARM on PineTab - by GreyLinux - 09-27-2020, 08:51 AM
RE: Arch Linux ARM on PineTab - by GreyLinux - 09-29-2020, 04:35 AM
RE: Arch Linux ARM on PineTab - by wd5gnr - 09-29-2020, 06:00 AM
RE: Arch Linux ARM on PineTab - by GreyLinux - 10-03-2020, 07:40 AM
RE: Arch Linux ARM on PineTab - by wd5gnr - 10-03-2020, 08:20 AM
RE: Arch Linux ARM on PineTab - by karlyn - 02-19-2021, 06:41 PM
RE: Arch Linux ARM on PineTab - by JasonG-FR - 02-21-2021, 01:05 PM
RE: Arch Linux ARM on PineTab - by RTP - 03-30-2021, 01:44 AM
RE: Arch Linux ARM on PineTab - by zqq - 06-09-2023, 07:49 AM
RE: Arch Linux ARM on PineTab - by fxc - 06-10-2023, 05:33 PM
  PineTab 2 login screen rotation fix chzbacon 11 4,159 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 2,118 02-24-2024, 12:29 PM
Last Post: Evergreen
  Working OS on pinetab RISC-V? user641 3 831 12-13-2023, 08:11 AM
  Arch Linux (danctnix) virtual keyboard layout change cudo 0 706 09-27-2023, 12:19 PM
Last Post: cudo
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 2,284 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 4,696 08-05-2023, 05:08 PM
Last Post: bingch
  PineTab 2 Login Failure cptijerina 0 705 06-07-2023, 07:16 PM
Last Post: cptijerina
Video Does DactNix Arch Linux support my use case? BlueGalaxy 22 6,211 05-18-2023, 03:45 AM
  PineTab Mobian bcnaz 150 147,441 04-26-2022, 11:58 AM
Last Post: thomzane
  Xmonad on PineTab Telefza 0 1,826 06-24-2021, 04:04 AM
Last Post: Telefza
