UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant)
#63
I re-dd'd and now stretched the partition using steps from https://xnux.eu/log/#toc-resizing-the-pa...-the-image.
A couple notes there (cc @megous)
1. I goofed on the block device (misread it) and fell back to my comfort zone of cfdisks which worked fine, too. I used '[resize]' on the second partition, then '[write]'.
2. the "$ df -h"  final step likely belongs *before* the umount so that you can see the size looks right Smile
That all went well and the Pine boots it so I thought to try the SailFish OS, again.
I can confirm that (after you set locale agree to EULA, etc.) when it says "Start" you can press as guided by the XDA dev (firmly, hold for a quarter second, towards the far corners, top left->right then bottom right->left) and it will skip the tutorial.
That being said, I still ended up in the same loopy place I did last time. It also says "Network Connection failed" despite being authenticated to my wifi. I did say "No Jolla Account" does that deny me from using the system? ?
Video footage of the foolishness and that'll be it for me and SFOS for a while: https://youtu.be/d_iKqvzPfK8
The funniest part was the part I didn't catch where holding the power button gave me a friendly "Goodbye!" before powering off from Jolla Wink
RE: UPDATED: 13-distro multi-boot image for Pinephone (incl. 3GiB variant) - by bujiraso - 09-19-2020, 05:38 AM
  Pinephone boot. Richy_T 4 77 10 hours ago
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 842 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 419 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 285 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,709 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,920 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 661 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,496 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 537 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,780 12-22-2023, 03:44 PM
