UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant)
#47
(09-15-2020, 08:52 PM)yoursunny Wrote: I flashed the Pinephone multi-boot image 2020-09-14 on my 3GB PinePhone.
I tested all 13 distros with a FreedomPop SIM, which is an AT&T MVNO, to determine whether cellular data can be activated.
Arch Linux ARM 2020-09-08
?️ CLI only, not tested.
Lune OS 0.113
❌ Missing APN config option.
Naemo Leste 20200906
❌ No cellular data menu.
Mobian 20200912
❌ 4G icon appears for 10 seconds and then disconnects.
KDE Neon 20200912-132511
❌ No SIM card listed in "Settings - Cellular Networks" menu.
pmOS / fbkeyboard 2020-09-11
pmOS / GNOME 2020-09-11
❓ I cannot get past initial setup screen on touchscreen because it's too wide.
pmOS / Phosh 2020-09-11
✅ Cellular data works.
? Setup screen is too wide, but I can workaround by changing to landscape layout to reach the "next" button.
? This is a different experience than the original postmarketOS factory image, which means the different kernel or modem power scripts in 13-distro image may have helped.
pmOS / Plasma Mobile 2020-09-11
❗ System freezes when tapping "Settings" icon, but "Settings" app works.
❓ For some reason the APN is already configured. It's possibly coming from the SIM card.
❓ I can't test ping or Firefox because virtual keyboard does not show up.
PureOS 20200908
Sailfish 1.1-3.3.0.16-devel-20200909
❓ Browser doesn't work but I can see the page title retrieved.
pmOS / sxmo 0.1.8-20200726
❓ No cellular data menu.
Ubuntu Touch 2020-09-10
⭕ Requires a reboot.
I started these tests booting from eMMC. However, after trying to use "pmOS / Plasma Mobile", the system in eMMC will only boot into Arch Linux instantly and the boot menu disappeared, so that I have to finish the rest of tests with SD card.
Thanks for all that testing.  Did you test/try Sailfish as well?
RE: UPDATED: 13-distro multi-boot image for Pinephone (incl. 3GiB variant) - by robthebold - 09-16-2020, 01:38 PM
  eSIM on PinePhone just_a_q 3 2,705 05-11-2024, 03:41 PM
Last Post: bam
  Pinephone boot. Richy_T 4 189 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 946 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 471 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 316 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 111,522 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,978 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 703 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,633 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 568 12-26-2023, 02:42 PM
Last Post: shengchieh
