PBP won't boot (no amber or green LED)
(08-20-2020, 05:55 PM)KC9UDX Wrote: Some metal paperclips these days are non-conductive.  They have a thin coat of plastic instead of galvanising.  You can scratch with a knife to see.
I think I know which paperclips you're talking about. Usually they come in fun colors. The one I tried was all metallic and didn't have a coating.
(08-20-2020, 06:04 PM)clover Wrote:
Quote:Also, can somebody tell me what it looks like when PBP is in maskrom mode? Does the laptop screen display anything? Should the power LED light up?
- Plug your usb-a end into your other computer and usb-c end into your pinebook pro
- On pinebook, get into maksrom mode. If you can't maskrom easily because SPI is bootable (only should be the case if you have flashed uboot or some other boot software to your SPI already) follow as400's guide
- Verify you are in maskrom. On other computer:
rkdeveloptool ld
look for maksrom output (e.g., DevNo=1 Vid=0x2207,Pid=0x330c,LocationID=1401 Maskrom)
Are you saying that the only indication that you're in maskrom mode is successful output from the rkdeveloptool command?
RE: PBP won't boot (no amber or green LED) - by ian-s-mcb - 08-20-2020, 06:04 PM
Sad What to can't boot from TF card, EMMC system broken - any advice?do guys? qingss0 1 2,330 12-18-2025, 01:05 AM
Last Post: qingss0
  Bonk to boot biketool 2 2,957 10-21-2025, 09:08 AM
  3 days in, slow/stuck or no boot. lgmpbp2 34 33,429 06-11-2025, 08:53 AM
Last Post: lgmpbp2
  upgrading u-boot--what version? where to get it? bsammon 14 20,553 04-03-2025, 07:47 AM
Last Post: Tazdevl
Tongue Yet another Pinebook Pro won't boot thread pinemouth 5 12,919 12-27-2024, 11:38 AM
Last Post: akash3995
  broken tow-boot hashkeeper 1 4,590 12-25-2024, 10:12 PM
Last Post: jessipinkman
  Cant boot into an OS trashtendenz 3 5,970 10-23-2024, 03:49 AM
Last Post: chaylengordon
  Unable to boot? YossiS 4 4,709 09-04-2024, 10:35 AM
  uboot wont boot to SD card after upgrade jbradley419 7 9,745 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 2,957 01-16-2024, 09:17 AM
Last Post: jbradley419
