Arch Linux Arm --> Kernel 5.8 breaks installation
(08-10-2020, 02:40 AM)t4_4t Wrote: Probably a boot-loader problem.
I tried using another boot-loader (mainline-base).
As a result, it starts normally as follows.
=> run bootcmd_mmc1
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot/boot.scr
890 bytes read in 5 ms (173.8 KiB/s)
## Executing script at 00500000
37171712 bytes read in 1612 ms (22 MiB/s)
50174 bytes read in 11 ms (4.3 MiB/s)
8339435 bytes read in 367 ms (21.7 MiB/s)
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f9f21000, end fa714feb ... OK
   Loading Device Tree to 00000000f9f11000, end 00000000f9f20fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.8.0-1-ARCH (builduser@leming) (aarch64-unknown-linux-gnu-gcc (GCC) 9.3.0, GNU ld (GNU Binutils) 2.34) #1 SMP Sun Aug 9 00:03:44 UTC 2020
[    0.000000] Machine model: Pine64 Rock64
[    0.000000] earlycon: uart8250 at MMIO32 0x00000000ff130000 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 64 MiB at 0x00000000fb000000
[    0.000000] Zone ranges:
Arch Linux 5.8.0-1-ARCH (ttyS2)
alarm login:
root@alarm:~# uname -a
Linux alarm 5.8.0-1-ARCH #1 SMP Sun Aug 9 00:03:44 UTC 2020 aarch64 GNU/Linux
Could you share your /boot/boot.scr?
RE: Arch Linux Arm --> Kernel 5.8 breaks installation - by m.bakhterev - 08-10-2020, 05:38 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 171 03-24-2024, 01:07 PM
  arch rock64 does not boot nemnob 0 612 07-09-2023, 03:28 AM
Last Post: nemnob
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 1,785 06-02-2023, 07:52 AM
Last Post: diederik
  Linux 5.15 Kernel - openSuse mark1250 0 1,306 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 6,902 10-22-2021, 05:45 AM
Last Post: kwinz
  Alpine Linux isndw 12 18,016 08-12-2021, 05:41 PM
Last Post: pix
Lightbulb RK3399 Linux rtl8822cu module bluetooth not working shivarj89 0 1,375 07-29-2021, 07:19 AM
Last Post: shivarj89
Information Linux Mainline ayufan 63 93,283 05-14-2021, 10:41 AM
Last Post: Wizzard
  Linux Images (ROCK64) pineadmin 164 283,502 02-12-2021, 10:14 AM
Last Post: useful64
  Debian kernel stuck at 4.4.167 Enig123 5 5,703 12-29-2020, 12:57 PM
Last Post: kwinz
