Arch Linux Arm --> Kernel 5.8 breaks installation
Probably a boot-loader problem.
I tried using another boot-loader (mainline-base).
As a result, it starts normally as follows.
=> run bootcmd_mmc1
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot/boot.scr
890 bytes read in 5 ms (173.8 KiB/s)
## Executing script at 00500000
37171712 bytes read in 1612 ms (22 MiB/s)
50174 bytes read in 11 ms (4.3 MiB/s)
8339435 bytes read in 367 ms (21.7 MiB/s)
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f9f21000, end fa714feb ... OK
   Loading Device Tree to 00000000f9f11000, end 00000000f9f20fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.8.0-1-ARCH (builduser@leming) (aarch64-unknown-linux-gnu-gcc (GCC) 9.3.0, GNU ld (GNU Binutils) 2.34) #1 SMP Sun Aug 9 00:03:44 UTC 2020
[    0.000000] Machine model: Pine64 Rock64
[    0.000000] earlycon: uart8250 at MMIO32 0x00000000ff130000 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 64 MiB at 0x00000000fb000000
[    0.000000] Zone ranges:
Arch Linux 5.8.0-1-ARCH (ttyS2)
alarm login:
root@alarm:~# uname -a
Linux alarm 5.8.0-1-ARCH #1 SMP Sun Aug 9 00:03:44 UTC 2020 aarch64 GNU/Linux
RE: Arch Linux Arm --> Kernel 5.8 breaks installation - by t4_4t - 08-10-2020, 02:40 AM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 16,902 03-07-2026, 11:04 AM
  How to boot an older, working kernel bits 0 2,081 11-01-2024, 04:43 PM
Last Post: bits
  Debian installation via sd card oaFJSADBKV 0 1,976 10-12-2024, 10:24 AM
Last Post: oaFJSADBKV
  arch rock64 does not boot nemnob 1 3,961 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  MIPI-CSI IMX214 on Linux NO SUCCESS zeus666 2 4,010 06-02-2023, 07:52 AM
Last Post: diederik
  Linux 5.15 Kernel - openSuse mark1250 0 2,549 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 12,279 10-22-2021, 05:45 AM
Last Post: kwinz
  Alpine Linux isndw 12 26,783 08-12-2021, 05:41 PM
Last Post: pix
Lightbulb RK3399 Linux rtl8822cu module bluetooth not working shivarj89 0 2,549 07-29-2021, 07:19 AM
Last Post: shivarj89
Information Linux Mainline ayufan 63 131,603 05-14-2021, 10:41 AM
Last Post: Wizzard
