touch screen API resources?
(08-05-2020, 10:57 AM)wibble Wrote: I was thinking more in terms of how it maps touch inputs to keyboard input for Wayland. Without knowing more about what you're aiming to do, it's hard to know whether you'd be looking at accessing the kernel driver interface directly (under /dev/input/ I expect) or providing an alternate input method at the X or Wayland level to use existing desktops with their respective accessibility features. Each has a different way of doing things.
Actually, I'm not really sure how my code should link in to the rest of the system and the other apps. The other BSI implementations I know about run on Android, Fire OS, and iOS. None of these are going to be the same as a "normal" Linux system, so I can't just copy their approaches.
It appears that Squeekboard uses D-Bus, which seems like a promising approach. Also, it might be possible to leverage Squeekboard in some manner (e.g., pretending to be an add-on hardware keyboard). Does D-Bus seem like a reasonable starting point?
touch screen API resources? - by Rich_Morin - 08-05-2020, 09:23 AM
RE: touch screen API resources? - by wibble - 08-05-2020, 10:57 AM
RE: touch screen API resources? - by Rich_Morin - 08-05-2020, 12:04 PM
RE: touch screen API resources? - by wibble - 08-10-2020, 06:30 AM
RE: touch screen API resources? - by Rich_Morin - 08-10-2020, 11:03 AM
RE: touch screen API resources? - by wibble - 08-10-2020, 06:58 PM
RE: touch screen API resources? - by Rich_Morin - 08-11-2020, 12:27 AM
RE: touch screen API resources? - by wibble - 08-11-2020, 08:22 AM
  Screen auto-rotation sensitivity mdk 0 297 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 672 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,333 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,249 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,027 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 1,574 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,879 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,263 07-18-2022, 03:29 AM
Last Post: vusra
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 870 07-17-2022, 10:34 AM
Last Post: 3x5co
  Won't boot, black screen mdk 4 2,780 07-03-2022, 06:38 PM
Last Post: Chief
