No USB connection - phone not seen!
@plainenough - I have been using the phone without the back extensively for cooling while testing.
Replaced back and:
1) held vol^ + power until RED led, eMMC UBPorts - udevadm monitor = no change.
2) held vol^ + power until GREEN led, eMMC UBPorts screen shows 'Awaiting command' - udevadm monitor responded (extract below, see https://bpa.st/MGTA):
ID_VENDOR=Pine64
ID_VENDOR_ENC=Pine64
ID_VENDOR_ID=1209
ID_MODEL=PinePhone
ID_MODEL_ENC=PinePhone
ID_MODEL_ID=4201
ID_REVISION=0506
ID_SERIAL=Pine64_PinePhone_Jumpdrive
ID_SERIAL_SHORT=Jumpdrive
ID_BUS=usb
ID_USB_INTERFACES=:0202ff:0a0000:080650:
ID_VENDOR_FROM_DATABASE=Generic
MAJOR=189
MINOR=3
Pc file system now shows various mounted partitions:
1.0 MB - boot.scr.
2.6 GB - android, bin, boot, dev, etc, home (etc).
67  MB - lost+gounf, dtb, initrd.img, vmlinux.
67  MB - lost+found, modules, config-5.6.0-pine64, dtb, initrd.img, System.map-5.6.0-pine64, vmlinuz.
8.4 MB - lost-found.
cache  - lost+found, recovery, system-image-upgrader.log.
userdata - android-data, system-data, user-data, .last_update, SWAP.img.
So it appears the usb/ethernet is probably electrically functional?
Normally booting the phone from eMMC/SD either inhibits usb starting or stops it. UBPorts direct flash mode provides apparently normal usb access leaving the phone in a state 'Awating command'. Does this imply that reflashing eMMC would solve the issue?
No USB connection - phone not seen! - by --- - 07-28-2020, 08:51 PM
RE: No USB connection - phone not seen! - by --- - 08-11-2020, 08:40 PM
RE: No USB connection - phone not seen! - by --- - 08-12-2020, 07:34 AM
RE: No USB connection - phone not seen! - by RTP - 08-12-2020, 01:07 PM
RE: No USB connection - phone not seen! - by --- - 09-01-2020, 12:08 PM
RE: No USB connection - phone not seen! - by --- - 08-28-2020, 06:21 AM
RE: No USB connection - phone not seen! - by RTP - 08-29-2020, 11:56 AM
RE: No USB connection - phone not seen! - by --- - 09-03-2020, 09:46 AM
RE: No USB connection - phone not seen! - by --- - 09-03-2020, 06:35 PM
RE: No USB connection - phone not seen! - by --- - 09-05-2020, 08:05 AM
RE: No USB connection - phone not seen! - by --- - 09-07-2020, 07:21 AM
RE: No USB connection - phone not seen! - by --- - 09-17-2020, 06:28 AM
RE: No USB connection - phone not seen! - by --- - 09-21-2020, 06:14 AM
RE: No USB connection - phone not seen! - by --- - 12-14-2020, 08:24 PM
Question No connection to internet without wifi :/ elode 3 2,651 03-16-2022, 04:15 PM
Last Post: bcnaz
  No automatic hub connection on reboot. --- 0 1,045 02-06-2022, 06:52 PM
Last Post: ---
  phone won't boot from emmc with sdcard inserted ssilvi 3 3,650 06-06-2021, 02:47 AM
Last Post: ssilvi
  Phone arrived: Stupid Questions begin. Setting up OpenVPN? OLOV 3 4,684 10-06-2020, 05:10 PM
Last Post: OLOV
  Cant shut phone down Cree 2 3,771 09-27-2020, 10:37 AM
Last Post: Cree
  Phone not detecting telco access points Pinoideae 6 7,248 09-23-2020, 06:04 AM
Last Post: Pinoideae
Information pmOS CE phone cannot boot from known good SD singpolyma 2 3,904 09-05-2020, 06:36 PM
Last Post: juanjoseor
  unable to boot the phone with PM OS after battery has completely discharged nieral 1 3,012 08-24-2020, 06:34 AM
Last Post: PureTryOut
  PMOS Community Edition phone,shipping OS bcnaz 1 2,960 08-22-2020, 03:30 AM
  How do I set the date and time on the phone? realrichardsharpe@gmail.com 2 4,854 03-03-2020, 08:08 PM
Last Post: pinerokc
