Screws broken off / General comment on inner Life of PB
(07-10-2020, 08:56 AM)Arwen Wrote: Use a jeweler screw driver. For installation, make sure the threads are lined up. I tend to insert the screw, then turn it back, (aka counter-clockwise), until I feel / hear the click. Then tighten no more than easy turns between 2 fingers on the jewelers screw driver.
Not many do the anti-clockwise click to engage the threads totally worth it to avoid cross-threading.
To the OP: you were totally crazy to use a power tool on the screws, asking for trouble. Did not stop after breaking the first one just carried on. Please use a screwdriver instead of power tools next time when you receive your replacement case that you have paid for NB check it comes with screws.
RE: Screws broken off / General comment on inner Life of PB - by lot378 - 07-12-2020, 11:18 AM
Question Broken Camera ? angeloweb 2 1,360 11-28-2022, 09:47 PM
Last Post: angeloweb
  Broken Screen vxzero 0 1,371 08-26-2021, 09:02 PM
Last Post: vxzero
  Pinebook Pro broken eDP connector Ocawesome101 4 6,563 01-16-2021, 11:42 PM
Last Post: dsimic
  PineBook Pro Screws WZ9V 4 5,896 08-15-2020, 05:37 PM
Last Post: WZ9V
  Pinebook Pro Broken Hinge uncmonky 1 3,218 08-02-2020, 01:43 PM
Last Post: Arwen
  Broken Spacebar on PBP ISO Jeremiah Cornelius 4 5,069 01-29-2020, 10:15 PM
Last Post: Jeremiah Cornelius
  PCIe 4X socket for optional NVMe adapter -retaing clip broken . ndp 9 10,947 12-19-2019, 05:15 AM
Last Post: ndp
Question Screws and standoffs for M.2 adaptor Thra11 2 4,342 07-27-2019, 05:45 PM
