noobie question regarding install
(07-03-2020, 06:43 AM)wibble Wrote: Also since Mobian provides the .bmap file you can save some time and flash write cycles by flashing with bmaptool rather than dd. The package will be called bmap-tools or similar. In theory Etcher can handle bmap files, but last I looked it wasn't working.
So, after some trial and error, I managed to install the Mobian 20200706 image onto my pine phone (Ubports community edition) emmc, using the jumpdrive. I am very grateful for all the work that has been put in to make it work! I'm embarrassed still to take so many detours getting there, but wow, Mobian really is getting things done!    I am hopeful once again that there can be a functional mobile phone without the bloatware, and that I am not forced to use the Apple nor Android. Thank you, thank you, thank you!!!
I've observed a couple of things that may help other noobies:
1) that I could actually take the battery out to charge (using my chinatown bought universal charger) while I flash the emmc using the jumpdrive on a micro SD. * The first time I flashed incorrectly to emmc the phone would not boot up, nor charge (likely because there was no OS) when I plugged in the power.  I was thinking I have bricked my phone. Two or three days went by before I had the courage to try again.
2) It helped to know what a properly flashed drive looks like. I saw the flashing process start and finish with no error  messages, but by the 5th time I realized that if the block says some such Gigs of "unknown", it's probably not going to boot the phone up.  (I have learned though, how to open the phone case, which is still a clumsy process but at least now i know how to not press on the power button accidentally while trying to open the case.
I do have a question for Wibble: what does one do with the .bmap file ?
noobie question regarding install - by HLing - 07-02-2020, 05:50 PM
RE: noobie question regarding install - by 0x070 - 07-02-2020, 06:06 PM
RE: noobie question regarding install - by HLing - 07-02-2020, 08:19 PM
RE: noobie question regarding install - by bcnaz - 07-02-2020, 08:24 PM
RE: noobie question regarding install - by devrtz - 07-02-2020, 09:45 PM
RE: noobie question regarding install - by wibble - 07-03-2020, 06:43 AM
RE: noobie question regarding install - by HLing - 07-03-2020, 09:05 AM
RE: noobie question regarding install - by HLing - 07-08-2020, 01:11 PM
RE: noobie question regarding install - by devrtz - 07-08-2020, 01:35 PM
RE: noobie question regarding install - by HLing - 07-08-2020, 01:59 PM
RE: noobie question regarding install - by devrtz - 07-08-2020, 02:19 PM
RE: noobie question regarding install - by HLing - 07-08-2020, 02:51 PM
RE: noobie question regarding install - by devrtz - 07-08-2020, 03:45 PM
RE: noobie question regarding install - by wibble - 07-08-2020, 04:00 PM
RE: noobie question regarding install - by devrtz - 07-08-2020, 04:11 PM
RE: noobie question regarding install - by HLing - 07-08-2020, 05:03 PM
  Waydroid install instructions end up attempting to use wrong URLS to aquire .debs chainingsolid 1 91 04-26-2024, 04:56 PM
Last Post: zetabeta
  Phoch Trixie weekly install seems nice reTestability 0 210 03-10-2024, 08:47 AM
Last Post: reTestability
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,067 11-22-2023, 11:46 AM
Last Post: aLoop100o
  apt trying to install a package version not in the repo chainingsolid 1 518 11-12-2023, 03:54 AM
Last Post: evilbunny
  Lock screen question: always squeekboard tuxcall 1 1,247 02-02-2023, 08:51 PM
Last Post: Haibara23
  Recent install, no wifi user641 3 1,509 01-12-2023, 03:06 PM
Last Post: user641
  snap install exceeded maximum runtime jojuma 0 797 07-17-2022, 07:52 AM
Last Post: jojuma
  Best/easiest way to install minimal Debian on PinePhone? mcgee 6 5,513 07-18-2021, 09:35 AM
Last Post: swiley
  Cannot install spotify, librespot or mopidy Gon 3 3,682 06-18-2021, 06:53 AM
Last Post: Gon
  firefox 79 will not install motox6 1 2,201 05-08-2021, 02:09 AM
Last Post: MtnSk8
