powerup upon plug event
I noticed my PBP was very warm after having put it to sleep then plugging in the power (this happens with the plug as well as with usb-c charging), and noticed that after more than half a day charging, it wasn't fully charged.
Then I tested, and found that it will turn on when I plug or unplug the power.
Is there any way to change this behaviour?
Or are there good reasons for it? (In case the keyboard malfunctions, it would be a way to turn on the device and then a usb keyboard could help out... just making wild assumptions why this behaviour might be designed in...)
For now I have configured Manjaro KDE to shut down after several minutes of idling even when running on mains power (I only had that setting when on battery power), have yet to test the setting.
The reason I have issues is that I have a generic 4 port usb charger device with a power switch on the mains cable, and it's not all that uncommon that it gets switched.
This conflicts with me assuming that after several hours, my PBP will be fully charged...
powerup upon plug event - by robt - 06-29-2020, 03:45 AM
RE: powerup upon plug event - by robt - 07-01-2020, 01:36 AM
RE: powerup upon plug event - by KC9UDX - 07-01-2020, 03:44 AM
RE: powerup upon plug event - by robt - 07-01-2020, 04:42 PM
RE: powerup upon plug event - by xmixahlx - 07-02-2020, 09:32 AM
RE: powerup upon plug event - by robt - 07-02-2020, 04:37 PM
Question Alternative plug-end for PBP wall wart? dumetrulo 4 5,612 03-10-2020, 12:12 PM
Last Post: zaius
