CrOS boot from sd, now pinebook doesn't boot anymore
Hi tophneal, thank you so much for your reply!
I've since flashed a new sd card with Chromium, and same issue, I only get an orange power light and a black screen.
The same happens when I don't have an SD card in it.
Then I tried to flash Manjaro ARM with KDE to the SD card. Tried to boot, still a black screen, yet at some point the light changes from orange to green.
I don't get why changes to the u-boot would have happened, and how to overwrite the u-boot.
I assume you are referring to this debian image?
https://github.com/mrfixit2001/debian_desktop/releases
Yet my PBP came with Manjaro, which seems it should not have been removed from the eMMC just by trying to boot Chromium from the SD card.
RE: CrOS boot from sd, now pinebook doesn't boot anymore - by qdoy55d9wkn8zw - 06-19-2020, 06:12 AM
  FydeOS for You - Pinebook Pro also1412 52 90,636 12-19-2022, 07:42 PM
Last Post: wangyukunshan
  Which OS can I actually run a 1080p pinebook non-pro? Scott104 1 3,305 10-09-2021, 02:47 PM
Last Post: TRS-80
  Panfrost and CrOS tophneal 2 5,200 04-20-2020, 12:23 PM
  CrOS debugging request brent.thierens 10 15,614 03-21-2020, 06:20 AM
Last Post: Hexxeh
Question Does the Pinebook Pro support chromium developer mode? TDC_PBP 3 7,622 12-07-2019, 02:33 PM
Last Post: TDC_PBP
