WiFi enabled but refuses to connect
(06-01-2020, 04:54 AM)pfeerick Wrote:
(05-31-2020, 01:36 PM)cardboardmaster Wrote: I turned on the wifi hardware switch
You mean the privacy switch? Once you've done that, you need to either poke the driver so that it talks to the wifi chip again, or reboot the machine.
Try the following, and if that doesn't work, reboot, as it didn't seem to work for me, and going by the latest on the wiki, should have.
sudo tee /sys/bus/platform/drivers/dwmmc_rockchip/{un,}bind <<< 'fe310000.dwmmc'
Hi Pfeerick,
I am a Rookie with Manjaro, bought a pinebook pro.
Istallation worked well, but wifi does not connect. NM shows no networks at all.
Any idea? Thanks.
RE: WiFi enabled but refuses to connect - by andreas.nauer - 06-01-2020, 10:06 AM
  Newbie unable to connect to internet Derek7 2 3,148 07-16-2021, 12:41 AM
Last Post: Derek7
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 2,949 02-02-2021, 12:13 AM
Last Post: PineSupporter
  Cannot charge and NO Wifi? jiapei100 3 5,514 06-27-2020, 02:11 PM
Last Post: jiapei100
  WiFi issues Pinebook Pro sunnystormy 6 9,156 05-28-2020, 05:44 PM
Last Post: Luke
  wifi issues george2524 9 10,965 06-13-2019, 04:25 PM
Last Post: evilbunny
  Is the Wifi module working? clawinus 8 10,803 11-23-2016, 10:09 AM
Last Post: clawinus
  how to install Wifi/Bluetooth module danlcarr 2 4,302 10-08-2016, 09:59 PM
Last Post: danlcarr
  WiFi module causes boot loop BnEc 17 25,743 09-24-2016, 09:12 PM
Last Post: pfeerick
  LCD works only when Wifi Module not installed nesalot 2 4,620 09-03-2016, 03:53 AM
Last Post: nesalot
  Wifi 802.11BGN/ Bluetooth 4.0 Module jesse1234 1 3,187 07-26-2016, 11:26 AM
Last Post: MarkHaysHarris777
