mobian installed to eMMC - how to install tow-boot
I have an older version of mobian installed to the eMMC in my PinePhone. Currently the image still boots with the help of uBoot. I was planning on installing a newer version of mobian to SD card after seeing the changes in the OS and UI that I discovered when I had to reinstall my PinePhone Pro. But current mobian images now need tow-boot to be installed.
If I understand correctly on the standard PinePhone, tow-boot has to be installed onto the eMMC. There are some things that are not clear to me after reading the instructions I have found ( https://tow-boot.org/devices/pine64-pinephoneA64.html )
a) will installing tow-boot to the eMMC wipe my mobian image that I have installed on the eMMC?
b) is it possible install tow-boat to an SD card?
c) is it possible to boot an image that was designed to use uBoot after tow-boot has been installed?
d) if the mobian image on the eMMC is written over when installing can I use say dd to copy the eMMC image to disc before installing tow-boot and then copy it back to eMMC after tow-boot is installed?
mobian installed to eMMC - how to install tow-boot - by grump_fiddle_reinstall - 07-01-2023, 07:53 AM
  Mobian MMS/SMS text problem bcnaz 16 39,989 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,924 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,608 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,565 10-08-2025, 06:21 AM
  New Install, apps start but don't show up on screen?! RT3 2 3,551 07-18-2025, 07:56 PM
  XLibre for Mobian Hiraghm 0 3,494 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 351,508 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,167 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,387 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,145 05-06-2025, 02:19 AM
