you probably need to add your user to the input group.: sudo adduser <user> input
kodi-git build script for mainline hwaccel media decoding
06-15-2020, 12:10 AM
(06-14-2020, 07:47 PM)xmixahlx Wrote: you probably need to add your user to the input group.: sudo adduser <user> inputYep that was the trick! I actually found that on some Kodi thread somewhere Now video playback fails to work, there's no content and it just gives me a nice cursor trail instead The kodi.log is getting spammed with: CDVDVideoCodecDRMPRIME::GetFormat - unsupported pixel format CDVDVideoCodecDRMPRIME::AddData - send packet failed: Invalid data found when processing input (-1094995529) Not sure where I went wrong
06-15-2020, 11:35 AM
your build steps need to be linux > (mesa) > ffmpeg > (libudfread) > kodi, with (package) being optional, but recommended. is that what you did?
06-15-2020, 03:49 PM
06-15-2020, 04:34 PM
are you building mesa? do you have X/wayland running?
kill X/wayland run: ffmpeg -re -hwaccel drm -hwaccel_device /dev/dri/card0 -i <VIDEOFILE> -pix_fmt bgra -report -t 1 -f fbdev /dev/fb0 upload the log here. it will be ffmpeg_date.log in the terminal directory. (06-13-2020, 09:28 AM)spikerguy Wrote: Hi @xmixahlx @spikerguy see CMakeLists.txt and note the -DENABLE_INTERNAL_?=OFF entries, and the ON entries under general. you may have to toggle those. also review required dependencies, and optional: https://github.com/xbmc/xbmc/blob/master/CMakeLists.txt from: https://gitlab.manjaro.org/manjaro-arm/p...r/PKGBUILD https://aur.archlinux.org/cgit/aur.git/t...h=kodi-git try: pacman -S afpfs-ng bluez-libs cmake curl doxygen glew gperf hicolor-icon-theme java-runtime libaacs libass libbluray libcdio libcec libgl mariadb-libs libmicrohttpd libmodplug libmpeg2 libnfs libplist libpulse libva libvdpau libxrandr libxslt lirc lzo mesa nasm python-pycryptodomex python-pillow python-pybluez python-simplejson shairplay smbclient taglib tinyxml swig upower giflib rapidjson ghostscript desktop-file-utils hicolor-icon-theme mesa python-pycryptodomex python-pillow python-simplejson xorg-xdpyinfo shairplay git meson gtest bluez-libs curl lcms2 libass libbluray libcdio libcec libinput libmicrohttpd libnfs libpulse libva libxkbcommon libxslt lirc mariadb-libs python smbclient taglib tinyxml libpng giflib libjpeg-turbo lzo afpfs-ng bluez python-pybluez libplist pulseaudio upower cmake .. \ -DCORE_PLATFORM_NAME=gbm \ -DGBM_RENDER_SYSTEM=gles \ -DFFMPEG_PATH=/usr/local \ -DENABLE_TESTING=OFF \ -DCMAKE_INSTALL_LIBDIR=/usr/local/lib/aarch64-linux-gnu \ -DENABLE_INTERNAL_FFMPEG=OFF \ -DENABLE_INTERNAL_FMT=ON \ -DENABLE_INTERNAL_CROSSGUID=ON \ -DENABLE_INTERNAL_FSTRCMP=ON \ -DENABLE_INTERNAL_FLATBUFFERS=ON \ -DENABLE_INTERNAL_SPDLOG=ON you may need to pair these down. when you get something that works, LMK. (06-15-2020, 04:34 PM)xmixahlx Wrote: are you building mesa? do you have X/wayland running?Yes I'm building mesa (KDE works great with it) and yes I'm trying to run kodi without x/wayland running at the time That test seems to work fine, I tried clearing my .kodi directory too but I'm really at a loss here ffmpeg-20200615-225201.log (Size: 44.61 KB / Downloads: 374)
06-16-2020, 02:23 AM
i updated the ffmpeg and kodi scripts. hopefully that solves both of your issues.
unclear why i don't see the same problems, but we'll figure it out. @spikerguy try BUILDCONFIG=internal ./pbp-build-kodi there is a change in installdirs: manually delete the old ffmpeg includes in /usr/local/include/aarch64-linux-gnu manually delete kodi libs in /usr/local/lib, i moved them to /usr/local/lib/aarch64-linux-gnu (06-16-2020, 02:23 AM)xmixahlx Wrote: i updated the ffmpeg and kodi scripts. hopefully that solves both of your issues. My latest build is working now, great work! 1080p H.264 and H.265 (even 10 bit!) are both working well Now hopefully some day the userspace apis will get figured out and we can run MPV on x/wayland but this is more than good enough for now |
