Cant boot into home-rolled Arch Linux image
As a learning experience, I've been trying to roll my own Arch Linux image. I've been cobbling together bits and pieces from the following locations while adding some bits of my own:
  1. anarsoul's build scripts
  2. Blutkoete's manual setup
  3. hku2's manual setup
  4. enospc's mostly upstream uboot
Below is a copy of my image building script. My issue is, after writing the image to my SD card and rebooting, my pinebook pro boots into debian on the eMMC. I figure I must be missing some important component to the boot process on ARM but I have no idea what that is. Since the pinebook boots into debian without showing me any sort of error message, I don't know how to debug this. Does anyone see what I am missing, or does anyone know how to get some more info out of the pinebook during boot?
#!/usr/bin/env bash
set -x
set -euo pipefail
IFS=$'\n\t'
DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
# Manual Steps
# Install dirmngr
# trust arch linux arm key
# gpg --recv-keys 68B3537F39A313B3E574D06777193F152BDBE6A6
WORKSPACE=$(mktemp -d -t "arch-pinebook-pro-build-XXXXXXX")
cleanup() {
   if [ -d "$MOUNT" ]; then
       umount -R "$MOUNT" || true
   fi
   if [ -z "$LOOP_DEVICE" ]; then
       losetup -d "$LOOP_DEVICE"
   fi
if [ -d "$WORKSPACE" ]; then
rm -rf "$WORKSPACE"
fi
trap cleanup EXIT
DOWNLOADS="$WORKSPACE/downloads"
mkdir -p "$DOWNLOADS"
ROOT="$WORKSPACE/root"
mkdir -p "$ROOT"
MOUNT="$WORKSPACE/mount"
mkdir -p "$MOUNT"
IMAGE_FILE="$WORKSPACE/archlinux.img"
IMAGE_SIZE="$(( 1024*1024*1024*6 ))" # bytes
archroot() {
   CHROOT="$1"
   shift 1
   CMD="$@"
   mount -o bind /tmp "$CHROOT/tmp"
   mount -o bind /dev "$CHROOT/dev"
   chroot "$CHROOT" mount -t proc proc /proc
   chroot "$CHROOT" mount -t sysfs sys /sys
   chroot "$CHROOT" "$CMD"
   chroot "$CHROOT" umount /sys
   chroot "$CHROOT" umount /proc
   umount "$CHROOT/dev"
   umount "$CHROOT/tmp"
wget -O "$DOWNLOADS/base.tar.gz.sig" http://os.archlinuxarm.org/os/ArchLinuxARM-aarch64-latest.tar.gz.sig
wget -O "$DOWNLOADS/base.tar.gz" http://os.archlinuxarm.org/os/ArchLinuxARM-aarch64-latest.tar.gz
gpg --verify "$DOWNLOADS/base.tar.gz.sig" "$DOWNLOADS/base.tar.gz"
# Disk positions (in bytes)
sector_size=512
boot_start=$((1024*1024*20))
boot_size=$((1024*1024*1024*1))
main_start=$((boot_start + boot_size + sector_size))
dd if=/dev/zero of="$IMAGE_FILE" bs=1 count=0 seek=$IMAGE_SIZE
fdisk "$IMAGE_FILE" <<EOF
o
n
p
1
$((boot_start/sector_size))
+$((boot_size/sector_size))
t
c
n
p
2
$((main_start/sector_size))
t
2
83
a
2
w
EOF
LOOP_DEVICE=$(losetup -f)
losetup -P $LOOP_DEVICE $IMAGE_FILE
dd if="$DIR/idbloader.img" of=$LOOP_DEVICE seek=64 conv=notrunc
dd if="$DIR/u-boot.itb" of=$LOOP_DEVICE seek=16384 conv=notrunc
mkfs.vfat -n BOOT -F32 ${LOOP_DEVICE}p1
mkfs.ext4 -L ARCH ${LOOP_DEVICE}p2
mount ${LOOP_DEVICE}p2 "$MOUNT"
mkdir "$MOUNT/boot"
mount ${LOOP_DEVICE}p1 "$MOUNT/boot"
# bsdtar too old on base pinebook install
#bsdtar -xpf "$DOWNLOADS/base.tar.gz" -C "$MOUNT"
# no genfstab on base pinebook install, do in chroot instead
# genfstab -U "$MOUNT" >> "$MOUNT/etc/fstab"
mv "$MOUNT/etc/resolv.conf" "$MOUNT/etc/resolv.conf.bak"
cp /etc/resolv.conf "$MOUNT/etc/resolv.conf"
cat > "$MOUNT/chroot_commands" <<EOF
#!/usr/bin/env bash
set -x
set -euo pipefail
IFS=$'\n\t'
pacman-key --init
pacman-key --populate archlinuxarm
killall -KILL gpg-agent
pacman -Syu --noconfirm
# wget to fetch manjaro packages
# arch-install-scripts for genfstab
pacman -S --noconfirm wget arch-install-scripts
mkdir /manjaro_packages
pushd .
cd /manjaro_packages
wget "http://ftp-nyc.osuosl.org/pub/manjaro-arm/repo/stable/aarch64/core/linux-pinebookpro-5.5.0-3-aarch64.pkg.tar.xz"
wget "http://ftp-nyc.osuosl.org/pub/manjaro-arm/repo/stable/aarch64/core/uboot-pinebookpro-2020.01-4-aarch64.pkg.tar.xz"
wget "http://ftp-nyc.osuosl.org/pub/manjaro-arm/repo/stable/aarch64/community/pinebookpro-post-install-20200203-1-any.pkg.tar.xz"
wget "http://ftp-nyc.osuosl.org/pub/manjaro-arm/repo/stable/aarch64/community/ap6256-firmware-2020.01-1-aarch64.pkg.tar.xz"
pacman -U linux-pinebookpro-5.5.0-3-aarch64.pkg.tar.xz
pacman -U uboot-pinebookpro-2020.01-4-aarch64.pkg.tar.xz
pacman -U pinebookpro-post-install-20200203-1-any.pkg.tar.xz
pacman -U ap6256-firmware-2020.01-1-aarch64.pkg.tar.xz
popd
genfstab -U / >> /etc/fstab
# clean up
#yes | pacman -Scc
EOF
chmod +x "$MOUNT/chroot_commands"
archroot "$MOUNT" "/chroot_commands"
rm "$MOUNT/chroot_commands"
mv "$MOUNT/etc/resolv.conf.bak" "$MOUNT/etc/resolv.conf"
sync
umount -R "$MOUNT"
cp $IMAGE_FILE "$DIR/archlinux.img"
Its worth noting that when I write the official manjaro image to the SD card, it does boot that successfully.
Anarsoul only release Pinebook build and not aware he has make one for Pinebook Pro. My takes you are using wrong build.
Thanks for replying, but I am not using his image. That list was a set of sources where I'm pulling information from. The image I'm generating is from my own script which I pasted above. In the script, I install the manjaro kernel for the pinebook pro and my uboot image is from a blog post for building uboot specifically for the pinebook pro. Is there another machine-specific part of the boot process that I'm missing?
You have root on a different partition than boot, so you need to modify /boot/boot.txt and run mkscr. You may also need to modify mkinitcpio.conf
This has helped me:
https://github.com/lsfxz/pinebookpro-thi...aster/luks
Ah thank you! As a temporary measure to test this, I moved everything down to 1 partition which worked. Now I just need to learn how to properly modify boot.txt for multiple paritions, but now that I have a working state to iterate from, that should be much easier. I'll have a look at that github repo.
  By the way, yay arch... KC9UDX 4 777 03-30-2024, 10:27 PM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,757 02-22-2024, 04:02 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 372 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,306 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 1,304 11-23-2023, 07:37 AM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,011 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,533 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 678 07-13-2023, 05:21 PM
Last Post: owaspfap
  Emergency Mode Boot Hotkey? jiacovelli 20 4,624 06-02-2023, 01:32 PM
  Kali Linux for Pinebook Pro Luke 100 161,304 05-03-2023, 06:10 AM
Last Post: dachalife
