Web browsing with plasma-mobile
I run PostmarketOS with plasma-mobile UI.
I have 2 browser installed :
- Firefox
- Angelfish
1- Firefox is running quite well, specially with the customization found here. However, I struggle to find a way to get a virtual keyboard running (the virtual keyboard from the distro do not show up when placing the cursor in a text field.
2- I can't run Angelfish : it launches, but impossible to load a page. I got this error :
pinephone:~$ angelfish
Using Wayland-EGL
Attribute Qt::AA_ShareOpenGLContexts must be set before QCoreApplication is created.
org.kde.kwindowsystem: Loaded plugin "/usr/lib/qt5/plugins/kf5/org.kde.kwindowsystem.platforms/KF5WindowSystemKWaylandPlugin.so" for platform "wayland"
file:///usr/lib/qt5/qml/org/kde/kirigami.2/Page.qml:362:9: QML Loader: Binding loop detected for property "active"
Loaded from file: 0 "/home/laurent/.config/angelfish/history.json"
qml: WebView completed.
qml: Settings: QQuickWebEngineSettings(0xaaab03cd3220)
qml: Current WebView is now : 0
Using the 'xdg-shell' shell integration
qml: Using homepage
qml: Loading url: https://start.duckduckgo.com
qrc:/WebView.qml:91: TypeError: Cannot read property 'editFlags' of undefined
qrc:/WebView.qml:96: TypeError: Cannot read property 'editFlags' of undefined
qrc:/WebView.qml:101: TypeError: Cannot read property 'editFlags' of undefined
qrc:/WebView.qml:105: TypeError: Cannot read property 'linkUrl' of undefined
qrc:/WebView.qml:118: TypeError: Cannot read property 'linkUrl' of undefined
../../3rdparty/chromium/sandbox/linux/seccomp-bpf-helpers/sigsys_handlers.cc:**CRASHING**:seccomp-bpf failure in syscall 0283
qml:     url: https://start.duckduckgo.com/
pinephone:~$
Do you know were to report bugs for angelfish ?
Did you manage to use any web browser with touch UI on postmarketOS ?
* PinePhone BraveHeart Edition
Try:
export QTWEBENGINE_DISABLE_SANDBOX=1
Before running angelfish. I've had that be successful on pmOS
I attached a virtual keyboard to the minibroswer from the QT Examples and I am using that.
It's not perfect, but it works.
I can you give you the repo if you're interested, you can compile it directly on the phone (given you have gcc and QT dev stuff, of course)
(02-17-2020, 08:27 AM)afigegoznaet Wrote: I attached a virtual keyboard to the minibroswer from the QT Examples and I am using that.
yes, thanks, this repo sounds interresting !
You can also add that environment variable to /etc/profile to avoid having to type the command everytime, and it works from the lauincher.
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
https://github.com/afigegoznaet/PinePhoneTest
  Gnome mobile user641 1 741 01-06-2024, 11:06 AM
Last Post: Uturn
  NextCloud Gnome Mobile Uturn 4 1,339 12-03-2023, 07:54 AM
Last Post: Uturn
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 911 10-03-2023, 06:32 PM
Question Always Use Mobile Data DingDangDoong 4 2,038 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 1,455 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,215 11-06-2022, 06:41 PM
Last Post: Chief
  Disable mobile data auto-enable on boot 64_Tesseract 3 2,394 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  [PostmarketOS with Plasma Mobile] Angelfish adblock + wpa supplicant time out Egolep 0 2,050 03-23-2021, 10:25 AM
Last Post: Egolep
  Phosh and Plasma together stozi 5 7,259 09-30-2020, 01:25 PM
Last Post: wibble
  Angelfish on Plasma Mobile not working fernando_c_m 4 6,176 09-06-2020, 10:31 PM
Last Post: bcnaz
